Got my hands on the new propane outboard today... - SailNet Community
 4Likes
post #1 of 22 Old 03-25-2012 Thread Starter
Closet Powerboater
MedSailor's Avatar
Anacortes was having a "boat show" this weekend, which was really just a chance for boat brokers to show off their stock, but there were a couple local yards and shops with tables out. One of the local yards had the LEHR propane outboards. I gave the 2.5 a good once over. Here's what I learned:
It looks well made and well thought out. There is a removable rubber plug in the cowling to access the spark plug for example and the oil change screw and oil fill are easy to get to. All controls felt strong and positive and seemed to be of high quality. Apparently it's a Yamaha engine and parts will be the same as yamaha 2.5hp parts.
What I was most interested in was run times. He had a chart and apparently at full throttle a 1lb bottle (or one pound worth of a larger bottle) will give you 60min at 4,000rpm which is wide open. 1/2 throttle, which is 3,000rpm (according to the chart) will give you 2hrs and 39min of run time per lb.
Starting is reportedly easy, but 3 pulls are required once you attach a propane bottle to prime the system. After that it's 1 pull till the bottle is empty.
The 2.5 does have a slot for 1lb bottles AND a fitting for attachment to larger cylenders. One very good piece of information is that LHER has a patent on a refillable 1lb bottle that is the same size, shape, and thread pattern as the disposable green ones. They're planning to mass manufacture refillable ones that have a real valve in them. Seems safer than the rubber ball "valve" on the disposable ones. Apparently they're hoping to enter the 1lb bottle market in a big way with exchangeable cylinders like you can now do with your BBQ bottles.
For me, if they have USER refillable 1lb bottles at a reasonable price, that would be enough to make me want to buy it. Have one in the motor and one in the dink and you've got lots of motoring time and you've got no mess, no gasoline spilling, no gasoline smell.
The big purchase budget for this year is already spent and or spoken for so we're not buying an outboard this year but I'll be keeping an eye on these things and touching base with the local seller periodically. I'll keep everyone posted on what I learn.
MedSailor
MedSailor is offline
post #2 of 22 Old 03-25-2012
skygazer's Avatar
Re: Got my hands on the new propane outboard today...
Interesting, I'd never heard of these. Thank you.
skygazer is offline
post #3 of 22 Old 03-25-2012
Lake Superior Sailor's Avatar
Yes;it is interesting & I'll keep watching as I'm not sold yet!But; I've been wrong before, so we will see. Spend your dime & let me know how it goes.. Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #4 of 22 Old 03-25-2012
Learning the HARD way...
eherlihy's Avatar
Thank you for the update!...
eherlihy is online now
post #5 of 22 Old 03-25-2012
Thanks for the update. Having Yamaha parts sounds like a winner.
elvishessler is online now
post #6 of 22 Old 03-25-2012
HANUMAN
RobGallagher's Avatar
Interesting, Thanks for the info.
RobGallagher is online now
post #7 of 22 Old 03-25-2012 Thread Starter
Closet Powerboater
MedSailor's Avatar
One of these sure would go well with the unit.
Composite LPG Tank
It's a composite propane tank that weighs 7.5lbs empty and holds 11lbs of propane. 18.5lbs total weight for the tank (when full) is much lighter than the motor itself and light enough to pass down by hand to the dinghy. No steel to rust all over your dink either.
11lbs of propane would give you 11hrs of motoring wide open and 26.5hrs at 1/2 throttle. The tank is also see-through so you can easily assess your fuel level.
I think I'm going to end up going the propane route.....
MedSailor
post #8 of 22 Old 07-18-2013
oceangirl's Avatar
Any updates on the motor?
~~Ocean Girl~~
~~Mrs. Rain Dog~~
1989 Pacific Seacraft Crealock 34 Hull# 142
oceangirl is offline
post #9 of 22 Old 07-18-2013
Thanks for this post. I assumed that these things would eat propane so fast they'd be worthless, but the numbers indicate they go quite a while!
Add to that that the 3 small outboards I take care of all have occasionally had carb issues associated with methanol. Maybe next dingy outboard, this will be the ticket?
capecodda is online now
post #10 of 22 Old 07-19-2013
Neosec's Avatar
Seems like a cool idea. I have a Propane heater (Mr. Heater) that uses disposable green propane bottles. I refill them using an adapter...
The disposable bottles are 3-4 dollars but refilling them costs about 75 cents.
I've had the disposable bottles off-gas a bit out the pressure relief valve as they warmed up after being (over)filled. So be sure to store them in a well ventilated area. Also remember Propane is heavier than air and will sink and pool (as a gas) on the floor or at the bottom of a locker/lazarette if the tank leaks.
Refill these at your own risk as they were not designed for doing so. I've heard the trick to refilling them is to bleed off the gas so the tank fills with liquid propane from an inverted 20lb cylinder...
A bit more info on propane vs gas. This link refers to running a generator but the math is the same for an outboard. Propane has less energy than gasoline so requires more of it to go the same distance...
Excerpts:
· Gasoline 1 gallon = 125,000 BTUs
· Natural Gas 1 CCF = 100,015 BTUs (CCF=100 cubic feet)
· Propane 1 gallon = 91,700 BTUs
Propane approximations
1 gallon = 91,500 BTU
1 cubic foot = 2,500 BTU
1 pound = 21,500 BTU
4.24 lbs = 1 gallon
36.39 cubic feet = 1 gallon
If we then enter the prices:
· ($2.65) x (10) for gasoline; ($.95) x (12.5) for natural gas; or, ($4.00) x (13.6) for propane
The cost for running the generator 24 hours is:
· $26.50 for gasoline; $11.88 for natural gas; or, $54.40 for propane
His propane cost seems high to me but I didn't research it.
The Relative Efficiency of Gasoline, Natural Gas, and Propane Fuels For Back-Up Generators
Propane is neat and clean and if you already has propane on board it seem like a good idea.
"Keep the company of those who seek the truth- RUN from those who have found it" ― Václav Havel
Neosec is offline
The Following 2 Users Say Thank You to Neosec For This Useful Post:
eherlihy (09-02-2014), oceangirl (07-19-2013)
New Lehr propane outboard davidpm Gear & Maintenance 75 09-24-2013 05:22 AM
Outboard Propane conversion? bljones Gear & Maintenance 4 01-19-2012 12:58 PM
Hands Across the Sand Skipper Joe General Discussion (sailing related) 17 06-28-2010 09:35 PM
Clr Run Through My Outboard/cool Longshaft Swap Today ;) stephenronning Gear & Maintenance 5 06-16-2009 01:02 AM
Look, Ma, No Hands! soulesailor General Discussion (sailing related) 3 11-15-2008 11:04 AM
