Shaft Question - SailNet Community
 1Likes
  • 1 Post By Maine Sail
post #1 of 8 Old 03-25-2012 Thread Starter
davidpm's Avatar
Shaft Question
The following are pictures from my friends O'day I took today.
I helped him remove the shaft.
He is planning on keeping the shaft and flange.
I did talk him into replacing the hose on the stuffing box but the
Stuffing box itself
bronze shaft with the serious scores between the cutlass bearing and the prop and the rusted flange he intends to keep.
Would you consider this a mistake as he has the engine out and the boat is in a garage where it is easy work on.
There are two pictures of the flange, before and after it was wire brushed.
The shaft seems very tight in the cutlass bearing so that seems OK.
Buy the way if you do decide to replace some of these parts where do you buy them?
P3250001 (Small).JPG   P3250004 (Small).JPG   P3250006 (Small).JPG   P3250005 (Small).JPG   P3250002 (Small).JPG
davidpm is offline
post #2 of 8 Old 03-25-2012
Lake Superior Sailor's Avatar
Re: Shaft Question
Other than the hose & packing look good! Most of the marks are from prop removal..Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #3 of 8 Old 03-25-2012
Re: Shaft Question
You should look for scoring where the flax rides on the shaft. If this is badly worn, it will be difficult to control seepage.
To replace the hose connecting the stuffing box to the stern tube you will probably need to remove the flange unless the engine is out and the shaft can be pulled forward. Pulling the flange can be a real bear. Don't cut off the old hose until you know how you're going to fit the replacement.
Hudsonian is offline
post #4 of 8 Old 03-25-2012
mitiempo's Avatar
Re: Shaft Question
davidpm posted that the engine was out.
Brian
mitiempo is offline
post #5 of 8 Old 03-25-2012 Thread Starter
davidpm's Avatar
Re: Shaft Question
That part is easy as the engine is out and we already got the shaft out of the boat but thanks for the warning.
I was going to suggest that he pull the flange from the shaft as it will be easy to do it now even though it is rusted on.
But I got to thinking that if he as problems in the future he is almost certainly going to just cut the shaft and replace it with SS. and hopefully that will be years from now.
davidpm is offline
post #6 of 8 Old 03-25-2012
Tartan 27' owner
CalebD's Avatar
Re: Shaft Question
David,
I'm just a bit ahead of you and your friend with the O'Day. We replaced our bronze shaft with a new SS shaft (around $225), Cutless bearing and shaft log hose. We re-used our coupling and stuffing box. Your friends coupling looks pretty rusty.
Most of those parts will clean up under a wire wheel fairly easily.
If his shaft is as worn as ours was I'd suggest replacing it.
Our drive train project documented here: 2011, November 30th. Begin drive train rebuild | Odalisque
We are mostly done with the drive train except a final alignment once she is in the water again. The hardest part is taking it all apart. Putting it back together was relatively simple.
Edit to add: Our shaft had likely seen 43 years of service so it was time to replace it.
Everybody has one:
CalebD is online now
post #7 of 8 Old 03-26-2012
Maine Sail's Avatar
Re: Shaft Question
The shaft at the prop nut end looks to be suffering quite badly from dezincification...
If there is any wear on the shaft and dezincification is present replace it. If you remove that coupling you will almost certainly NEED to replace it. Straight couplings need to be a light press / interference fit.... Even the smallest layer of rust broken free changes this from an interference fit to a clearance fit. Clearance fit = BAD...... I suspect your friend is being penny wise pound foolish.... Those old Tobin bronze shafts had lots of zinc in them. When they turn coppery colored, like the nut end of that shaft, they are usually toast.
jameswilson29 likes this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #8 of 8 Old 03-26-2012 Thread Starter
davidpm's Avatar
Re: Shaft Question
That sure sounds right.
If the bronze is dezincified then I suspect that what happens is that flange just falls off the crumbled shaft.
Is that about right.
If not what is the likely mode of failure?
davidpm is offline
Cal 29 prop shaft question weststar Cal 13 09-18-2014 11:36 PM
Converting a short shaft to a long shaft PaulinVictoria Gear & Maintenance 10 02-04-2012 08:05 PM
Replacing the hose between the propeller shaft stuffing box and shaft log tube jameswilson29 Gear & Maintenance 34 12-14-2011 04:20 PM
Dripless Shaft Packing Question JimMcGee Gear & Maintenance 5 03-18-2009 12:01 PM
PSS Shaft Seal Question danielgoldberg Gear & Maintenance 16 03-24-2008 11:53 AM
