Prop...painting it - Page 2 - SailNet Community
 2Likes
post #11 of 19 Old 03-26-2012
Re: Prop...painting it
With the Pettit Zinc Coat, the hardest part is making sure your running gear is nice and clean. Assuming that, you can apply 3 coats of paint in less than 10 minutes. Comes in a spray can. No need to prime. Easy and cheap. Doesn't get any better than that.
Catalina 34
chuck53 is offline
post #12 of 19 Old 03-26-2012
But if not...
rather than the Pettit brand ($$) try the cheaper alternative from Lowe's. Same ingredients, much lower price.
paperbird is offline
post #13 of 19 Old 03-26-2012
T37Chef's Avatar
Pettit Zinc Coat as mentioned usually works great, I had been using it for several years with great results, only the last year, 2010 season, did I see some barnacle growth on the prop and shaft, but that summer we had very high water temps, so not much of anything faired well. Still, the growth came off easily when the boat was pulled with a pressure washer and some scraping.
http://www.pettitpaint.com/fileshare...ds/1179320.pdf
Check out this pic
antifouling for a bronze propeller
Shawn
T37Chef is offline
post #14 of 19 Old 03-26-2012 Thread Starter
Thank you to everyone. I work in IT, and all my list servs I use for my job this is the best one....
You guys rock!
Ian Lyons
Sea Lyons
Hunter 326
Narragansett Bay
lyonsian is offline
post #15 of 19 Old 03-26-2012
Closet Powerboater
MedSailor's Avatar
Great advice on the Pettit product! Thanks everyone!
So...... if regular copper bottom paint eats bronze...... should I not be painting my bronze through-hulls with bottom paint? All the other kids are doing it.
MedSailor
MedSailor is offline
post #16 of 19 Old 03-27-2012
I don't discuss my member
Fstbttms's Avatar
It doesn't. Don't worry about it.
WanderingStar likes this.
Fstbttms is offline
post #17 of 19 Old 03-27-2012
I've been told that a well polished surface is harder for hard growth to attach to. I had my prop repaired this winter and it is so shiny you can see yourself in it. I can't get myself to paint it. I will let you know in the Fall how this works out. We will typically have a half dozen barnacles per blade. My best estimate is we will only have 5 this year...........
Jeanneau 54DS
Minnewaska is offline
post #18 of 19 Old 03-27-2012
Closet Powerboater
MedSailor's Avatar
Actually I'm not particularly worried about it, exactly BECAUSE everybody does it, including commercial boats. It just causes me to question the wisdom of not painting the bronze prop with copper paint. Why would one be a no-no and the other okay?
MedSailor
post #19 of 19 Old 03-27-2012
JimsCAL's Avatar
MedSailor
The reason given is that electrolysis causes dezincification of the bronze. That said, I put regular bottom paint on the prop of my previous boat for years and never saw that problem. I used the Pettit Zinc Barnacle spray last season with mixed results. Better than nothing but prop still needed regular cleaning to remove growth.
JimsCAL is offline
1 inch prop on 25mm prop shaft? lawsonmitchell Gear & Maintenance 12 07-12-2014 06:50 PM
Upgrade prop to a feathering prop patrscoe Gear & Maintenance 47 01-03-2012 11:11 PM
Feathering Prop vs. Fixed Blade Prop Benevento Pacific Seacraft 70 02-11-2011 07:52 AM
New Prop & Shaft - install prop questions preservedkillick Gear & Maintenance 2 05-22-2010 08:46 AM
Zincs for Sail Prop feathering prop jrbarn Gear & Maintenance 4 09-20-2006 10:40 AM
