Prop...painting it - SailNet Community
 2Likes
post #1 of 19 Old 03-26-2012 Thread Starter
Prop...painting it
Hello
This past season, the new Marina I live at caused EVERYTHING not coated in bottom paint to become covered with barnacles.
I have seen people paint their Brass props with bottom paint. While I never thought of doing that, as I never felt the urge to look up how does brass and copper (in the paint) co habitat.... Now I find myself looking up that info.
I vaguely remember something in chemistry about that.
So, the real question is...has anyone done this (as far as the chemistry brass vs copper it is all cool) but should I do this? Does it pit the prop?
The 2 hours of scraping barnacles and sanding is not something I wish to do again...or atleast at this level of effort.
Ian Lyons
Sea Lyons
Hunter 326
Narragansett Bay
lyonsian is offline
post #2 of 19 Old 03-26-2012
Senior Smart Aleck
jameswilson29's Avatar
Re: Prop...painting it
Look at the beautiful photo of my prop painted with zinc paint...
SailNet Community - jameswilson29's Album: Winter repairs: replace propeller - Picture
...done after posting a similar post to yours.
jameswilson29 is offline
post #3 of 19 Old 03-26-2012
Tim R.'s Avatar
I doubt anything the marina did caused this increased growth. Probably warmer water temps to blame. Either way, you are better off not painting and just cleaning the prop periodically. You can paint it but the AF paint must be isolated from the bronze.
mitiempo likes this.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #4 of 19 Old 03-26-2012
Irrationally Exuberant
Props aren't brass, they're bronze. And as I understand it, yes there is an interaction between the copper and the bronze, which will weaken the bronze. I think you'd be OK if you paint the prop first with an epoxy barrier coat and then bottom paint. BTW, I just spray my prop with zinc transducer paint and this seems to fight off the barnacles.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #5 of 19 Old 03-26-2012
Courtney the Dancer
jrd22's Avatar
There was another thread about this not too long ago and a lot of folks recommended a prop and drive paint, I think it was a Petit product. I've used Trilux prop and drive spray paint over a zinc chromate primer for several years now and it has worked very well, no barnacles.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #6 of 19 Old 03-26-2012
Using Pettit Zinc Coat Barnicle Barrier #1792 on Bronze prop for 1st time this year.
Made for use on metal/bronze.
Have heard good things from multiple sources including other sailnet threads.
HUGOSALT is offline
post #7 of 19 Old 03-26-2012
Oh yea...forgot...product is grey. Took some maning up to spray my beautiful
flex o fold prop gray...but then I remembered what it looked like coming out
of the water last fall.
HUGOSALT is offline
post #8 of 19 Old 03-26-2012
When it comes to running gear, Prop Speed is probably the best you can buy, but expensive and very labor intensive to use.
Pettit Zinc Coat is cheap and easy to use and does a very good job. Hard to beat.
Catalina 34
chuck53 is offline
post #9 of 19 Old 03-26-2012
RichH's Avatar
Petit Zinc Coat Barnacle Barrier .... Great stuff and relatively inexpensive.
No need to 'isolate' from the bronze with any intermediate coating.
Its primarily a zinc rich coating and if any 'seed' barncales do attach they are 'stunted' from growing and their 'adhesion' is very limited ... and can be 'wiped off'.
I sail many thousands of miles per year ... the barnacle barrier holds up quite well.
I keep my boat in the upper Chesapeake where barnacle growth, in the increasingly warm & increasingly very turbid water, has gone 'exponential' in slime and barnacles in the past few years. Many bottom paints are no longer useful there vs. 'hard growth' ... but the Barnacle Barrier 'really' works very well on the prop.
RichH is offline
post #10 of 19 Old 03-26-2012
I've been using a hard bottom paint on the prop for the past 10 years with good results however you first need to prep the prop first with an underwater metal primer. I've been using Petit products and two thin coats of bottom paint.(Bluewater paint with high Cu content)
lancelot9898 is offline
1 inch prop on 25mm prop shaft? lawsonmitchell Gear & Maintenance 12 07-12-2014 07:50 PM
Upgrade prop to a feathering prop patrscoe Gear & Maintenance 47 01-04-2012 12:11 AM
Feathering Prop vs. Fixed Blade Prop Benevento Pacific Seacraft 70 02-11-2011 08:52 AM
New Prop & Shaft - install prop questions preservedkillick Gear & Maintenance 2 05-22-2010 09:46 AM
Zincs for Sail Prop feathering prop jrbarn Gear & Maintenance 4 09-20-2006 11:40 AM
