Cunningham and boom vang set-up? - SailNet Community
post #1 of 5 Old 03-27-2012 Thread Starter
itsaboat's Avatar
My boat has a 4:1 vang set-up from the boom to an eye in the sail track. It is secured in the sail track with two non-ss screws. I am concerned that the screws are starting to deteriorate, but I am afraid to try to back them out since they will likely twist off. Or, they are secured internally by nuts which would fall into the mast and would be there for another season.
The mast is on a sturdy ss plate with many holes on the four flanges. I am planning to use this plate to rig blocks to lead the halyards aft through a deck organizer in the future. Would it be better to mount the vang to the plate as well?
I also want to rig a cunningham. I was thinking a 4:1 system? Too much purchase? What are the recommendations on this?
Pearson 27
itsaboat is offline
post #2 of 5 Old 03-27-2012
Re: Cunningham and boom vang set-up?
If your mast base plate (deck stepped, I assume??) is strong enough it may well be a better place for the vang connection. Do try to keep the pivot point of the lower block on the same axis as the gooesneck if you can. Keep in mind the vang gets some heavy loads on it in a breeze downwind. 4:1 is a bit marginal but may be enough if you're just cruising. It's easy to double it, though, with a single block and a part back to the base. Here's an image from the Harken catalogue.
You could do a similar thing with the cunningham, use a 4 part tackle but take a lead off the top block, up through the cringle and back down to the gooseneck. For less friction a block with a hook could be used at the cringle instead of dragging through the eye in the sail.
Using a more powerful tackle allows use of smaller line, and better ease of adjustment meaning you'll use it more often.
Faster is online now
post #3 of 5 Old 03-27-2012
Gary M's Avatar
I think the mast plate would be a much better place to attached your vang. Info on what boat would be helpful.
Again not knowing how big your main is but for my Cunningham on a 30 foot boat with a big main I have I believe three to one.
I just tried to describe how I set it up but my memory fails me again
Gary M is offline
post #4 of 5 Old 03-27-2012 Thread Starter
itsaboat's Avatar
Faster: Yep, it is deck stepped. I could easily double the purchase by moving it to the base plate and running the line through an extra block at the boom as you show in the diagram, thanks. I just replaced the line with a new 3/8" Sta-set and bought enough to still give me enough to run to the cockpit later I think.
I will look at setting up the cunningham like you described as well.
Gary: The boat is a Pearson 27. Sorry, I put that in the signature not the body. Here is the best picture I have at the moment of the set-up. (Pardon the sail trim; the luff is saggy in the pic and winds were light and variable that day. We had just raised the main and fixed the trim later.)
Pearson 27
itsaboat is offline
post #5 of 5 Old 03-30-2012
tap
You have an eye bolted inside the sail track?
Like this:
My mast has a crack in its butt - Sailing Anarchy Forums
I suggest changing it.
tap is offline
Boom/Cunningham setup XPatriot General Discussion (sailing related) 1 05-16-2011 01:30 PM
Adding rigid vang + Cunningham ereuter Gear & Maintenance 5 08-16-2008 08:53 AM
boom vang and cunningham. Leland Gear & Maintenance 9 05-20-2008 10:51 PM
[New Video Out] The Boom Jack or Boom Vang Giulietta General Discussion (sailing related) 8 01-23-2008 10:33 PM
Vang/Cunningham T34C Gear & Maintenance 16 12-10-2006 02:23 PM
