Make my own gaskets??? - SailNet Community
post #1 of 4 Old 11-25-2003 Thread Starter
I need to aquire a gasket kit for a Volvo MD7A engine because I am in the process of tearing down this engine because it was submerged, and I want to inspect and clean up the engine inside and out and paint the outside and oil and replace bad parts. I was wondering if I could save some money by making my own gaskets, and has anyone ever attempted to do so? Thanks for the replies. John
john232 is offline
post #2 of 4 Old 11-25-2003
Moderator
Jeff_H's Avatar
When I was a kid we rebuilt a Renault Dauphine and later when I raced motorcycles, we made many of our own gaskets. It is pretty hard to do well. Gasket material was not all that cheap so we would ''prototype'' a gasket out of shirt cardboards (do dry cleaners still put cardboard in folded shirts), dry assemble the part and often have to make two or three protypes before making a final good one. It greatly added to the time that we spent on the project in making patterns, cutting them out, test fitting them and remaking the ones that did not work out.
There are some gaskets like the head gaskets that are inadvisable to make (especially on a diesel)and others that you must buy because of a special material or shape. There are some pieces that rely on a proper gasket thickness to work properly. Diesel injector pump gaskets are one of those.
I would think that the savings would be too small to be worth the risk of completely lunching the engine and having to start over again.
Jeff_H is offline
post #3 of 4 Old 11-25-2003
The volvo cylinder base gaskets are measured in the thousands of an inch. it would be very difficult to cut them from stock.
Dave R.
windancer1 is offline
post #4 of 4 Old 12-04-2003
FloridaWriter's Avatar
I would spend the money for a factory gasket kit.
FloridaWriter is offline
Goop to use for gaskets on bronze ports sadie14 Gear & Maintenance 1 04-07-2004 09:42 AM
How to make a simple zig zag stitch?? gwp Gear & Maintenance 2 06-08-2003 01:20 PM
First time in cruising, in mexico, on a 20'' sloop. jbarros Cruising & Liveaboard Forum 7 08-29-2002 09:28 AM
oday 272 porthole gaskets pats29 Gear & Maintenance 0 04-24-2002 05:45 PM
How to make and use a Leadline karlheinz Seamanship & Navigation 7 03-30-2001 01:38 PM
