Snatch Blocks; In desperate need of cleaning - SailNet Community
 1Likes
post #1 of 13 Old 03-28-2012 Thread Starter
In going through the new to me boat I removed 7 snatch blocks (with a N M insignia) and they are in need of cleaning. The spring pin on the shackle is very stiff on most of them. I disassembled the sheaves and found they are in very sad shape. I plan to soak them and the roller bearings in a can of kerosene (paraffin for you folks that speak funny English) or maybe Simple Green full strength.
Question is when I reassemble them should I put a light coating of lithium grease on the roller bearings (a la Winches) or just a light oil?
sailordave is offline
post #2 of 13 Old 03-28-2012
I don't discuss my member
zz4gta's Avatar
Re: Snatch Blocks; In desperate need of cleaning
Are they snatch blocks, or just blocks with a snap shackle on them?
Merit 25 # 764 "Audrey"
zz4gta is offline
post #3 of 13 Old 03-28-2012 Thread Starter
Oh, they're snatch blocks!
post #4 of 13 Old 03-28-2012
Senior Moment Member
SloopJonB's Avatar
Clean the shackle pin with WD40 or another penetrant. Squirt some in and work the pin in & out - repeat and repeat until it works smoothly. Those pins always tighten up if they aren't worked regularly.
For the rollers, if kerosene doesn't do the trick, try diesel - it cleans things very well, if you can stand the smell. A little white lithium should keep them rolling nicely - be sparing with it or you'll have it on your deck & sails.
SloopJonB is online now
post #5 of 13 Old 03-28-2012
You may wish to polish the pistons --a fresh dollar bill works well -- and lube with McLube.
Hudsonian is online now
post #6 of 13 Old 03-29-2012
SloopJonB's Avatar
Since when is a $1 bill good enough for ANYTHING on a sailboat?
post #7 of 13 Old 03-29-2012
Old as Dirt!
svHyLyte's Avatar
Roller bearings are designed to roll. Adding grease or oil will allow them to collect debris which inhibits there action. A preferred treatment is a thorough dosing with SailKote dry lubricant before reassembling the blocks. Boeing T-9 seems to be a better treatment for the shackle pins once the surface rust is removed.
FWIW...
svHyLyte is offline
post #8 of 13 Old 03-29-2012 Thread Starter
FWIW...
That's what I was wondering. Some of the sheaves are caked w/ gunk. Some of fairly clean and dry and seem to be working just fine. I've stripped winches a gazillion times but never had to tear down a snatch block. I'll try a dry lube and see how it works. Thanks.
post #9 of 13 Old 03-29-2012
SloopJonB's Avatar
Roller bearings are designed to roll. Adding grease or oil will allow them to collect debris which inhibits there action. FWIW...
That's exactly why I use white lithium - it doesn't seem to hold dirt & debris like heavier greases.
Don't those dry lubricants require frequent recoating?
post #10 of 13 Old 03-29-2012
Crossion X from APS works really well.
Gary3675 is offline
In desperate need of advice. WFerguson Boat Review and Purchase Forum 6 02-17-2011 03:47 PM
Snatch block for misc. use? n0w0rries Gear & Maintenance 15 02-23-2010 07:52 PM
Double Snatch Block? danielgoldberg Gear & Maintenance 13 04-07-2008 10:40 AM
Snatch block placement on S2 8.0 overholtzer S2 2 09-11-2007 06:46 PM
Equivalent of snatch block, but for clutch or cam? labatt Gear & Maintenance 14 04-10-2007 04:18 PM
