Raw water hose - SailNet Community
 5Likes
post #1 of 13 Old 03-29-2012 Thread Starter
davidpm's Avatar
Raw water hose
I'm still stumped by this one.
It is a Volvo Penta Model 2002.
The hose does not seem to reach the raw water through hull.
Is there supposed to be a filter there that someone has removed?
Maybe an elbow?
I can't find any pictures that make sense.
Maybe I could just stretch the host and make it reach but that doesn't seem likely either?
davidpm is offline
post #2 of 13 Old 03-29-2012
jbrockpiano's Avatar
Re: Raw water hose
Most likely the raw water strainer was removed. The strainer is important as it keeps bits of sea debris out of your engine. You should install a new one before running your engine.
jbrockpiano is offline
post #3 of 13 Old 03-29-2012
Re: Raw water hose
kinda looks like a hose barb (hard to tell) on the valve... maybe someone cut the hose? Also likely that valve is not screwed onto the thruhull by more than a turn or two so you might not want to put much strain on that as it is...
Faster is online now
post #4 of 13 Old 03-30-2012
mitiempo's Avatar
Re: Raw water hose
If the hose is too short replace it. There should be a strainer installed above the waterline so it can be cleared without a flood.
HPLou, Tempest and davidpm like this.
Brian
mitiempo is online now
post #5 of 13 Old 03-30-2012
Courtney the Dancer
jrd22's Avatar
Re: Raw water hose
I bet if you look you'll find where the screws went that held the strainer on the wall there. I would install a strainer and get another piece of hose and king nipple to go from the through hull to the strainer and a king nipple to attach the hose you have to the strainer. Bummer, the good strainers aren't cheap.
davidpm likes this.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #6 of 13 Old 03-30-2012
jackdale's Avatar
Re: Raw water hose
Not all sea strainers are/were installed above the waterline. They should be.
That being said, there should be a sea strainer in place.
davidpm likes this.
jackdale is offline
post #7 of 13 Old 03-31-2012
mitiempo's Avatar
Re: Raw water hose
A strainer like this isn't very expensive.
Shurflo Raw Water Strainers
Brian
post #8 of 13 Old 04-01-2012 Thread Starter
davidpm's Avatar
Re: Raw water hose
I have some evidence that the hose was cut. There are no clamp marks.
That would explain it being short.
I had to cut the other end to remove it so I'm not surprised it was a problem.
The hose might be imperial and the barbs metric. They seem to be a very very tight fit.
davidpm is offline
post #9 of 13 Old 04-01-2012
One of None
deniseO30's Avatar
Re: Raw water hose
Strainer was removed because someone didn't winterize the boat and it split open?
My last project!
deniseO30 is offline
post #10 of 13 Old 04-01-2012
mitiempo's Avatar
Re: Raw water hose
If the boat was built in France it could be metric - doubtful if built in Carolina though.
Brian
Best hose for the head sea water intake? MarkSF Gear & Maintenance 11 07-25-2011 12:52 PM
raw water intake hose diameter Tanley Gear & Maintenance 6 03-29-2010 04:46 PM
Fastening water hose to bulkhead garymcg Gear & Maintenance 2 06-24-2009 07:19 AM
cooling water hose size on 2GM??? Northeaster Gear & Maintenance 1 04-30-2009 12:17 PM
Water hose Danielle Gear & Maintenance 3 12-24-2005 03:30 PM
