Electrical Mystery. Need help. - SailNet Community
post #1 of 18 Old 03-30-2012 Thread Starter
creedence623's Avatar
This is a question for all the electrically inclined folks out there because it has me absolutely baffled.
When I turn on the instrument circuit breaker, the wind speed and tri-data displays take about 10 minutes before they come on. Same thing with the autopilot.
What in the world would cause a 10 minute delay in supplying power to devices when the breaker is turned on?!
S/V FREEDOM
2002 Beneteau 393
I'm a sailor, I sail!
creedence623 is offline
post #2 of 18 Old 03-30-2012
marcusc130's Avatar
Corrosion in the breaker maybe. Check the contacts. Low amperage makes electronics do funky stuff.
marcusc130 is offline
post #3 of 18 Old 03-30-2012 Thread Starter
Re: Electrical Mystery. Need help.
I didn't notice an at the breaker panel, but I'll check the length of the wire runs as best I can. Low amperage could make sense, Ill try to measure resistance as well.
S/V FREEDOM
2002 Beneteau 393
post #4 of 18 Old 03-30-2012
I think I'd also suspect the breaker itself. Does this problem affect everything on this breaker? They can get temperamental when they get old.
MarkSF is offline
post #5 of 18 Old 03-30-2012
AdamLein's Avatar
Is it always ten minutes? Or is it one minute sometimes, five sometimes, ten sometimes, fifteen sometimes, etc.?
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #6 of 18 Old 03-30-2012 Thread Starter
The only things on this breaker are the 2 Raymarine displays: wind speed/direction, and a tri-data. The autopilot circuit breaker is separate and the autopilot has the same 10 minute delay.
While the delay isn't exactly 10 minutes, it is consistantly the same amount of time before powering up.
S/V FREEDOM
2002 Beneteau 393
post #7 of 18 Old 03-30-2012
Bradhamlet's Avatar
What is the state of charge, 12.2 or under will cause some delays.
Bradhamlet is offline
post #8 of 18 Old 03-30-2012
asdf38's Avatar
Right, if it's a bad connection you'd expect it to be somewhat random. You'd also expect it to turn off sometimes (this is what happens with my depth sounder and spreader lights..).
I don't know, something time dependent makes me think heat. Perhaps there is a marginal, highly resistive connection which heats up causing it to change shape and make a better connection. But it's highly unlikely that it could happen independently on two different circuits.
Do they all come on at the same time? Do you have a voltage meter on your panel, is it reading ok? Bottom line I think you need to get out there with a multi-meter and start following the circuit path. Measure the voltage along the way. At least it's re-producible.
The length of the wire shouldn't be a factor. Remember to keep things straight, low current would be caused by high resistance which would also cause low voltage at your load. You can't have one of these things without the others, ohms law always holds true.
Generally I can't see how high resistance/low current/low voltage would cause a delay - it should result in no operation or flaky operation but not a delay behavior.
asdf38 is offline
post #9 of 18 Old 03-30-2012
If your having other ccts affected I'd start looking for grounding issues...
Faster is offline
post #10 of 18 Old 03-30-2012
AdamLein's Avatar
That was my thinking as well.
I think he means "I will check all parts of the wire" rather than "I will measure the length and see if the resulting number indicates a problem."
That said, longer conductors provide linearly greater resistance.
AdamLein is offline
Mystery - pls help perrygv Sailboat Design and Construction 11 06-29-2015 12:22 AM
Indentifying Mystery Hardware (Mystery to me anyway) :) krozet Gear & Maintenance 7 04-19-2010 04:26 PM
(engine related) electrical mystery pegasus1457 Diesel 3 07-19-2009 09:43 PM
