Toe rail bedding - SailNet Community
 1Likes
  • 1 Post By SloopJonB
post #1 of 5 Old 03-30-2012 Thread Starter
Barquito
Barquito's Avatar
Toe rail bedding
I have most of the hardware off my deck in order to paint and re-bed everything. Looking at the wooden toe-rail, it looks like it is concave on the bottom. When I put the toe rail back on should this gap be filled with butyl, or is is supposed to be an air gap? The toe rail covers the hull-deck bolts.
Barquito is offline
post #2 of 5 Old 03-30-2012
Junior member, rest old
msmith10's Avatar
Re: Toe rail bedding
It was probably made with a concavity to keep it from rocking. Was there bedding compound originally?
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #3 of 5 Old 03-30-2012
Senior Moment Member
SloopJonB's Avatar
Fill it - it will never be an "air gap", only a crud gap and/or a rot gap.
mitiempo likes this.
SloopJonB is online now
post #4 of 5 Old 03-31-2012
Ticon 30
dbruce85's Avatar
I will ask the question again to keep the thread going, as I have refinished my teak toe rails and am about to reattach. They are screwed in with #10 screws.
When I removed them there was traces of butyl and also white caulk, not sure what kind.
I have cleaned the deck, what should I use to seal them?
dbruce85 is offline
post #5 of 5 Old 03-31-2012
SloopJonB's Avatar
I'd use a low adhesion polyurethane - 3M 4200, Sikkens 291 or the like. If you use the high adhesion stuff like 5200 you'll have to destroy them to ever get them off again.
I've no experience with butyl tape but everything I've read about it referred to bedding metal or plastic onto metal or plastic, not wood. I don't know how, or if it works sealing wood.
Bedding one more time davidpm Gear & Maintenance 4 09-21-2011 03:47 PM
Which goop for bedding jephotog Gear & Maintenance 17 10-14-2009 11:06 AM
Sealant for bedding steel hardware on teak rail? josrulz Gear & Maintenance 3 06-05-2009 05:06 PM
Rebedding Mahogany Toe Rail & Rub Rail Finallybuyingaboat Gear & Maintenance 3 03-15-2009 10:28 AM
Re-bedding jib car track L124C Gear & Maintenance 12 11-25-2008 06:47 PM
