Boot strip - Page 2 - SailNet Community
 1Likes
post #11 of 12 Old 04-02-2012
Re: Boot strip
Originally Posted by Ritchard View Post
In response to Tempests post above, I recently removed some accent striping prior to a repaint of both the cove and boot stripes. I simply used the heat gun. Warm up the glue a little bit and it comes right off - though you want to be careful not to overheat the vinyl to where it begins to melt and it breaks. I took off nearly 200 feet of stripe in about 2 hours - and a good bit of that was repositioning ladders.
A little acetone or MEK afterwards and the glue is gone.
Richard, My old cove stripe was probably 20 years old. The top layer in many spots was gone, and just the thin backing remained. Where there was tape it was cracked through. The Heat gun worked great, but because of all the cracking I could only peel tiny amounts at a time. No big peels. Often the top layer would come off leaving the thin backing, which I soaked in hot soapy water, to get most of it, then wiped the rest with acetone. I wasn't in a hurry, I did a section each spring for a few years until it was all gone. I wasn't going to let it keep me from getting in the water. Yes, moving the ladder was time consuming..would have helped to have a rolling scaffold.
If the tape wasn't aged and cracked the way it was, I imagine the whole job would have gone easier.
tempest is offline
post #12 of 12 Old 04-02-2012
No more curry buffets
Ritchard's Avatar
Re: Boot strip
Ahh, sounds like your vinyl was way older/more destroyed than mine, mine may have been 6 or 8 yrs. Nasty job, that.
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is offline
What kind of Weather strip is this? lans0012 Gear & Maintenance 2 01-23-2012 10:32 PM
Best way to strip wax? TakeFive Gear & Maintenance 15 04-21-2011 09:51 PM
Better way to strip RG-8 / RG 213? thekeip Gear & Maintenance 6 06-11-2009 08:42 AM
Peel Away Marine Strip II foxglove Gear & Maintenance 2 03-05-2004 05:31 PM
If I strip, will you look at my bottom? VIEXILE Gear & Maintenance 3 12-08-2001 03:30 PM
