Difficult shifting - SailNet Community
post #1 of 5 Old 04-02-2012 Thread Starter
Difficult shifting
Anyone have an S2, Yanmar engine, that is really, really hard to shift into forward and reverse? We disconnected the cable at the transmission, and the shift lever is smooth as silk, like cutting butter. Hook it back up and you really have to lean into it to get it in gear. There is fresh fluid in it. Maybe wearing out inside?
NikOfTime is offline
post #2 of 5 Old 04-02-2012
Re: Difficult shifting
Do you mean the shift lever on the pedestal or on the trans? If at the trans seems like it's a cable problem.
"Just call me TB"
capttb is offline
post #3 of 5 Old 04-02-2012
trantor12020's Avatar
disconnect cable from trans & throttle at engine end. try shifting the control lever at pedestal and at engine side and see where your problem is.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
trantor12020 is offline
post #4 of 5 Old 04-02-2012 Thread Starter
Shift lever at steering station and cable are not the problem. We disconnected the cable at the transmission, and cable and shift lever at the steering station were fine. The problem is at or in the transmission. Also, no problem with throttle whatsoever.
post #5 of 5 Old 04-02-2012
Disconnect the cable, start the motor, and see if you can change gear by shifting the lever by hand. It sounds like you will not be able to. If so, then you have a gearbox problem.
Watch that the shift quadrant on the gearbox is not fouling the water pump or something. It happened to be last winter when I drained the coolant on my Volvo MD17C. I inadvertently moved the water pump a wee bit, and the gearshift qaudrant was catching the pump. It took a while to see what had happened.
If you have a gearbox problem, then at least you don't have a Volvo gearbox on there. It would be financially terminal if you did.
Rockter is offline
Shifting Shoals? OtterGreen General Discussion (sailing related) 0 09-02-2011 02:38 PM
Poles Shifting hackandhue General Discussion (sailing related) 17 01-25-2011 12:03 PM
A4: Stalling when shifting from neutral CLucas Atomic 4 8 08-13-2009 01:31 PM
mast shifting sailboatman35 Sailboat Design and Construction 2 05-27-2008 10:05 AM
Shifting gears at the helm ccboston Seamanship & Navigation 3 03-02-2004 08:03 PM
