Removing mystery deck paint - SailNet Community
post #1 of 18 Old 04-02-2012 Thread Starter
I have a 1972 Flying Scot with very hard, badly flaking white deck paint of unknown origin. This white "paint" is on top of the original beige gelcoat, and it is very hard. I can break off bits of flake, and they are very hard and inflexible. I'm not sure if this is a second layer of gelcoat, or epoxy paint, or what? I've tried peel-away, but the "paint" seems impervious. I've made very slow progress with 80 grit random orbital, but that looks like weeks of work. Does anyone know of a paint remover that will work on epoxy paint without damaging the underlying gelcoat?
gosell is offline
post #2 of 18 Old 04-02-2012
Re: Removing mystery deck paint
NO, sorry. I have a simular problem. I finally tried the usual paint solvents, staying away from stronger ones that would harm the gel coat.
After removing as much as I could that way, none of them softened the paint much, and I didn't want to go too extreme. I finally just sanded and scraped as much as I could. Then painted over the rest with a good quality deck paint.
I know I just kicked the problem down the road, but the boat looks good right now, and if I get a few years of use without further peeling I'm good.
The Sun has Risen on a New Day filled with the Promise of Adventure.
CapnBilll is offline
post #3 of 18 Old 04-02-2012
Tartan 27' owner
CalebD's Avatar
Have you tried Acetone? or MEK (Methyl ethyl ketone)?
Without knowing if it is a paint or gelcoat its kind of hard to say what will work besides a sander.
Everybody has one:
CalebD is online now
post #4 of 18 Old 04-02-2012
Senior Moment Member
SloopJonB's Avatar
Go to 40 grit. 80 is an intermediate grit for a job like that - use 40, then 60 and THEN 80. After that you can start working with "finish" grits.
SloopJonB is offline
post #5 of 18 Old 04-02-2012
Hardened epoxy is forever, there are no solvents to remove it IF it is truly epoxy.
Which means either sanding, grinding, or media blasting. If the blast guy is good, he might be able to soda blast it with just enough pressure to take off the epocy without damaging the gelcoat. Maybe soda, maybe a different media, but that's the approach I'd look into.
hellosailor is offline
post #6 of 18 Old 04-02-2012 Thread Starter
Thanks to all of you for your good input. Acetone has no effect, I'll try some MEK on a small test spot. I think 40 grit may be the ticket, although 80 was the coarsest grade I saw in Lowes. I hear people talk about using grinders. I've got one and I can't imagine controlling it well enough to not gouge the heck out of the boat.
gosell is offline
post #7 of 18 Old 04-02-2012
Tartan 27' owner
CalebD's Avatar
With my 4-1/2" grinder I use the round sandpaper disks on it and find that it is pretty easy to control using a light touch. I use it for quick and dirty fine adjustments with some woodworking projects. These sanding disks only come in a few grit sizes.
Carpet cutters razor blades might be useful for chipping up the loose spots. These blades are about 1/2" x 4" long and stronger then std. razors.
If your paint is unaffected by Acetone I have my doubts that MEK will work except that MEK is used by some as a thinner for epoxy.
Good luck.
Everybody has one:
post #8 of 18 Old 04-02-2012
Roadkillibus Texanis
retclt's Avatar
Respirator and inexpensive sand blaster. Works miracles.
Bob T
"I cannot not sail" - E. B. White
retclt is offline
post #9 of 18 Old 04-02-2012
SloopJonB's Avatar
NEVER use a grinder on a hull or deck - you will ruin it - for sure!
post #10 of 18 Old 04-02-2012
Barquito
Barquito's Avatar
I agree with both. I am grinding non-skid off my deck. Takes forever with RA sander. With a really (really) careful technique, I can get a smooth result with a grinder. It is so much faster with the grinder. It is worth having to patch a few spots caused by over-agressive grinding. If you are going to be patching some dings and painting anyway, it doesn't add much work.
Barquito is offline
Tags
flaking , paint remover
Mystery bottom paint tpothen Gear & Maintenance 7 03-21-2011 06:50 PM
Painting over mystery paint. L124C Gear & Maintenance 7 04-23-2009 01:04 AM
removing paint on hypalon rappitysnap Gear & Maintenance 2 03-16-2009 09:38 AM
Mystery rash on bottom paint thekeip Gear & Maintenance 3 02-21-2008 01:39 AM
Removing paint Jotun General Discussion (sailing related) 23 11-15-2006 09:47 PM
