Diesel winterizing - SailNet Community
post #1 of 5 Old 04-03-2012 Thread Starter
davidpm's Avatar
Diesel winterizing
The bene 32s5 with a volvo 2002 I'm working on was winterized by someone I have no access to.
This engine has an indirect cooling circuit with fresh water.
I noticed that the freshwater tank was empty.
This is the tank in the picture.
Have you every heard of someone winterizing a diesel and this tank ends up being empty?
You can see the tank in the upper right hand corner.
davidpm is offline
post #2 of 5 Old 04-03-2012
chef2sail's Avatar
Re: Diesel winterizing
No,
But i do know some people who drain their systems entirely.
Thats the overflow or fill tank, open the radiator cap and see if there is antifreeze in there. I would suggest you flkush and replace anyway as its your cooling system and its nice to know that it is pristine. Make sure you do not flush the toxic variety into the water. There are other types to use.
dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #3 of 5 Old 04-03-2012
It shouldn't be freshwater, but rather coolant, which is a form of anti-freeze. Therefore, if it's in good condition, it doesnt need to be drained.
I agree with Chef, that I would flush it several times. Be careful with flushing chemicals, as you could knock calcification free, which could plug passageways. If empty, I would highly consider pulling the exhaust elbow and heat exchanger to have a look and clean them up separately. Maybe replace the thermostat too.
Jeanneau 54DS
Minnewaska is offline
post #4 of 5 Old 04-03-2012 Thread Starter
davidpm's Avatar
I was talking to a dock rat and he says that he has heard that some folks like to drain an engine of all coolant under the theory that if their is nothing their it can't freeze.
There is some green coolant in the bilge under the engine I need to sponge out.
davidpm is offline
post #5 of 5 Old 04-04-2012
JimsCAL's Avatar
You shouldn't have coolant in the bilge. That may explain the low level in the overflow tank. You may have a leak in the coolant system.
JimsCAL is offline
Diesel Winterizing Question arf145 Gear & Maintenance 22 11-05-2007 12:37 PM
Winterizing a diesel canadianseamonkey Gear & Maintenance 14 08-29-2007 12:16 AM
diesel life and winterizing purplehazer Gear & Maintenance 3 10-29-2006 07:58 PM
Winterizing Inboard Diesel offline2004 Gear & Maintenance 3 10-03-2006 09:52 AM
How much winterizing do I need? foxglove Gear & Maintenance 7 09-18-2004 01:22 PM
