C&C 30 MK1 Pressurized alcohol stoves - SailNet Community
 4Likes
post #1 of 17 Old 04-03-2012 Thread Starter
First String
So I have read a lot of forums on this topic. The stove on this C&C looks like new. We are not going to be going anywhere for quite some time. Just spending some weekends and overnights. Do I go thru it and learn how to use it? Or do I just use a rail mounted BBQ from west? I like the stove idea but I don’t want a fire. or explosion!! Does anybody have instructions on how a factory installed 3 burner pressurized stove works?? How to prime, how many pumps from the bicycle pump do you give the tank, how much fuel to put into the tanks? etc.
Thanks in advance for your help and advice.
ltgoshen is offline
post #2 of 17 Old 04-03-2012
Re: C&C 30 MK1 Pressurized alcohol stoves
Biggest issue with these, other than the hassle of preheating, is the cost of the proper fuel.. cheap methyl hydrate will plug things up so you need to use the proper alcohol.
They are also slower to heat than propane and we never did have success with the 'oven' in 10 years with a pressurized alcohol stove. We kept it for that long for all the usual reasons, but finally switched to propane and never looked back.
A bbq isn't great for toast in the morning, or that cup of coffee, so trying to go bbq alone really isn't a good plan.
If you choose to use the stove preheating is greatly simplified by heating the burner itself for a minute or two with a propane torch.. never mind the raw alcohol puddle that burns with eye stinging fumes and so close to invisible that you can't tell when it's getting away on you. Pump up the tank, heat the burner with the torch and then slowly open the fuel valve.. the burner will light off the torch flame smoothly and burn clean from that point.
Use the self lighting torch tips available at any hardware store for convenience.. it does mean having propane aboard, but with common sense that's manageable..
Faster is online now
post #3 of 17 Old 04-03-2012
Chastened
Ajax_MD's Avatar
I understand your trepidation.
Consider replacing it with an Origo, non-pressurized alcohol stove. They put out the same or more BTU's as these old pressurized stoves. In the meantime, you can at least test the safety of yours by pressurizing it a little and checking for leaks before you light it. I'll bet there's a manual online for it somewhere.
olson34 likes this.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is online now
post #4 of 17 Old 04-03-2012
dinosdad's Avatar
Go to C&C Yachts - C&C Photo Album & Resource Center , look under
The section marked manuals, they have the pressure stove manual there.
Let me know how you make out, I bought a c&c 30 mk1 this fall..
Havnt messed with the stove yet....
chef2sail and ltgoshen like this.
dinosdad is online now
post #5 of 17 Old 04-03-2012
ASA and PSIA Instructor
Keep your jug of drinking water open and nearby when using the stove, if you have a flare up, you can drown it in water.
Remember that the alcohol flame is very difficult to see in daylight.
(I hate those stoves...)
mitiempo likes this.
sailingfool is offline
post #6 of 17 Old 04-03-2012
Junior member, rest old
msmith10's Avatar
I second the motion to go to an Origo. That's exactly what I did on my C&C 30 Mk 1. I had the Hillerange pressurized alcohol stove and oven on mine- probably the same one you have. Forget the oven. Plan to preheat the burners on the stove and be ready for flare-ups when you first light it up. You won't know it's flaring up until the curtains catch on fire because you can't see the flame.
I went to the Origo because:
1.safer
2. easier to use
3. removing the Hillerange gave me a ton of space- installed a counter in its place and microwave fits under the counter.
You can install a gimbal system for the Origo if you need it.
If I had the money for a proper propane installation, that's the way I'd go, but that's an expensive proposition.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #7 of 17 Old 04-03-2012 Thread Starter
First String
Here is a photo of mine.[IMG]Photobucket[/IMG]
ltgoshen is offline
post #8 of 17 Old 04-03-2012
tommays's Avatar
I Have the Hillerange and it makes so nervous i have never lit it
I think i will take it to the driveway and play with it to gain some trust in how it works as it did work fine for 40 soem odd years for the PO
and i have no problem at all using a coleman white gas stove
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #9 of 17 Old 04-03-2012
JimsCAL's Avatar
I used Kenyon pressurized stoves for many years and got pretty good at dealing with their quirks. I did replace the one on my previous boat with an Origo when I got a great deal on one and it was a great improvement. My advice is try the Hillerange and see how it works. If you don't like it, get an Origo.
JimsCAL is online now
post #10 of 17 Old 04-03-2012
chef2sail's Avatar
You have got to be kidding...water will spread the fire....
Fire needs oxygen to burn. Keep a box of baking soda nearby. It will suffacate the fire. Every station in my restaurants had a box near in for all the little fires we would always have. Simple is better. of course make sure you have the proper extinquisher on board
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
Stoves - pressurized alcohol or propane, which is better? 7tiger7 Boat Review and Purchase Forum 26 12-15-2008 01:04 PM
Priming pressurized alcohol stoves. L124C Gear & Maintenance 8 12-13-2008 12:16 PM
Non-Pressurized Alcohol Stove SEMIJim Gear & Maintenance 32 11-09-2007 10:53 PM
Alcohol Stoves Mark Matthews Gear and Maintenance Articles 0 10-26-2001 08:00 PM
Alcohol Stoves Mark Matthews Cruising Articles 0 10-26-2001 08:00 PM
