wheel grip material - SailNet Community
post #1 of 12 Old 04-04-2012 Thread Starter
wheel grip material
We have a 6 spoke steel wheel in the cockpit. It's painted white, and is about 2 1/2 feet in diameter. I'd like to put a good grip material on it and am looking for suggestions. Advice on wrapping technique would also be appreciated.
Thanks.
extremo is offline
post #2 of 12 Old 04-04-2012
Re: wheel grip material
Something like this??
Looks awesome in my opinion..
But i suspect it is quite a job on such a large steering wheel...
Coxcombing
Somekindofaviking is offline
post #3 of 12 Old 04-04-2012
Battered and Bruised
Silvio's Avatar
Coxcombing
How to Tie a Single-Strand Ringbolt Hitch by TIAT - YouTube
oooooh, I like that!
SV S.S.R.I
It's my happy pill
Silvio is offline
post #4 of 12 Old 04-04-2012
Just Google : wrap steering wheel with rope- Or leather, Or .......
Plenty of hint's tricks, and video's......
post #5 of 12 Old 04-04-2012
FSMike's Avatar
There's also a company that will coat your wheel in a rubber type of material in various colors.
I often contemplate having that done, usually while holding on to my stainless wheel in a thunderstorm.
Sail Fast Live Slow
36' Solaris Sunstar catamaran
FSMike is offline
post #6 of 12 Old 04-04-2012
Why not just do it yourself ??
Industrial Protective Coatings & Adhesives, Plastic Coatings, Protective Foam Coatings
If you take off the steering wheel, and let it rotate slowly while it dries..
(mount it to a slow rev electric motor)
You can avoid uneven buildups of material at the lowest point.
Wooden steering wheels are dipped in clear coat/varnish baths while they rotate.
And dried that way also...
post #7 of 12 Old 04-06-2012
Rope is traditional, but will take you time. Elkhide, oddly enough, seems to be the top choice for leather wraps. It doesn't mind being out in the elements the way that other leathers do, and you can buy kits to match the wheel diameter, just lace them up and you're done.
hellosailor is offline
post #8 of 12 Old 04-06-2012
Cool Re: wheel grip material
Boat Leather, Leather Products for the Marine Environment
I just bought a kit for our ss wheel. Looks do-able, but then things always look easy when an expert does them.
We shall see how it goes.............
and then there's Plan B:
About Us - Color Wheelz, a high tech covering for your sailboat steering wheel.
I almost went with the the plastic dip idea, but the other guy talked me into the leather grip when I fell under his magic spell at the boat show!
LB
olson34 is offline
post #9 of 12 Old 04-07-2012
St Anna's Avatar
Varnish....once every couple of years
I know, different wheel..
St Anna is offline
post #10 of 12 Old 04-07-2012
pdqaltair's Avatar
Sail Delmarva: A Handfull of Minor PDQ Upgrades
Simply wrapping the wheel with line does a great job. Our helm is under a big hard top, protected from rain and UV, so I used cotton/poly 1/4-inch clothes line. If it were exposed I would use an inexpensive polyester yacht braid. Perhaps a 20-minute job, to get it nice and tight. We have not needed to re-tension. It gets a little dirty and at some point I'll replace it, but I bet I'll get over 5 years out of it.
I like the way cocks coaming looks just fine, but I don't like the feel.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
Kiwi Grip Pics CorvetteGuy Gear & Maintenance 4 10-07-2011 02:49 PM
kiwi grip non-skid deckhanddave Gear & Maintenance 25 03-01-2010 02:28 PM
Antal V-Grip clutch jarcher Gear & Maintenance 0 06-21-2009 03:03 PM
Awl Grip Polisher ambianceack Gear & Maintenance 6 04-12-2007 09:35 PM
Getting a Grip Don Casey Gear and Maintenance Articles 0 04-11-2004 08:00 PM
