What happens if you just ignore a rusty keel - SailNet Community
post #1 of 6 Old 04-05-2012 Thread Starter
davidpm's Avatar
If you have an iron keel that has a tendency to rust what happens if every year you just chip off the loose stuff. Wire brush what you can and bottom paint.
It will get worse and worse of course but what it the worst that will happen?
It will look nasty.
It will not be smooth so will slow the boat down a 10th of a knot.
I don't think you will loose enough iron in 10 years to cause any ballast issues.
The keel is not going to fall off.
Can you think of any other down side to ignoring the rough keel.
davidpm is offline
post #2 of 6 Old 04-05-2012
Superior Sailor
Squidd's Avatar
Re: What happens if you just ignore a rusty keel
Be honest that's my plan too..
Clean it brush it and paint it do touch ups as neccessary..
A. I'm in fresh water
B. I'm on a trailer so minimal "soaking" time
C. I can do touchups week to week or a slightly larger job once a year ( I store boat at home)
D. The whole sand blast, epoxy prime and glass an 1/8" thick seems like overkill for my needs.
E. I don't believe it's gonna go all to hell in 5-6 months...
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is offline
post #3 of 6 Old 04-05-2012
It does mean the same routine on every haulout whereas if you spend one haulout getting it properly treated and sealed that's the last time for awhile.
But essentially if you're prepared to do that work each year (and don't leave it for several seasons undone) then you'll suffer the loss of speed and the OMG looks each time you lift it!
Personally (as one with an iron keel) I prefer the sealed approach and the minimal work each year (and the option to get two seasons out of a bottom job).
Faster is offline
post #4 of 6 Old 04-05-2012 Thread Starter
davidpm's Avatar
At about 250 for paint two season from a bottom job has some merit.
davidpm is offline
post #5 of 6 Old 04-05-2012
Senior Moment Member
SloopJonB's Avatar
It will look nasty.
It will continue to rust and get scabbier and lumpier.
It will slow you down a lot more than 1/10th.
It will require a lot of nasty work every year just to keep it in SOME kind of shape.
It very well MIGHT fall off - see the attached pic of what was somehow holding my iron keel on when I bought the boat.
I included a pic of what I replaced it with.
SloopJonB is offline
post #6 of 6 Old 04-05-2012
blt2ski's Avatar
I'm wondering if the rust could work its way back and into where the bolts are........causing a much worst issue than doing it right sooner than later.....
I had to redo about 4 yrs ago the iron keel I had, Pulled out a year ago after 3.5 yrs in the water, only needed some caulking at the keel/hull joint, and repaint. Should be good for another 20-25 yrs if the original epoxy covering went that long.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
Rusty Keel Bolts - How bad is it? Fodder Boat Review and Purchase Forum 39 02-06-2017 02:11 AM
Rusty Keel Bolts kjones Gear & Maintenance 9 01-10-2012 10:45 AM
Rusty Keel Bolts IslandSword SailNet FAQ 1 03-26-2011 06:47 PM
Rusty Keel Bolt thevdeub Gear & Maintenance 4 11-15-2010 12:04 PM
Rusty spots on keel and hull keel joint Stephane99 Gear & Maintenance 1 04-07-2009 07:39 PM
