Plug for my rudder - SailNet Community
post #1 of 3 Old 04-08-2012 Thread Starter
nauticalrich's Avatar
Plug for my rudder
Need some good advice.
I drilled a 3/8 inch hole in the bottom of the rudder to drain the water.
Someone in the yard told me to put a lag bolt in the hole so I can drain it everytime I haul out for the winter.
Any suggestions on the best way to do that?
nauticalrich
1985 31 Oday
Bridgeport, CT
nauticalrich is offline
post #2 of 3 Old 04-08-2012
mitiempo's Avatar
Re: Plug for my rudder
I wouldn't use a lag bolt. I would use a machine screw after tapping the hole for the proper thread. Use some SikaFlex on the threads before inserting the bolt.
Also keep in mind that if there is water in a rudder it can damage the stainless framework that is its strength. Many rudders are rebuilt for this reason.
Brian
mitiempo is offline
post #3 of 3 Old 04-09-2012
Rich, make it easy. Buy some PC7, a thick epoxy that comes in two little cans, or something similar. It is something like a peanut butter consistency, very easy to work with. Or, buya tube of 5200 or 4200, a good adhesive caulk.
Once the rudder is dry, plug the hole, let it set up for 24 hours before you splash the boat. Next year, just drill another hole in the same spot.
A bolt, any kinf of bolt, may or may not seal completely and will add some srag to the rudder on the one side. So...Make it simple, plug the hole flush, skip the bolt.
FWIW once you have water in the rudder, it is never dry, and it is on the road to failure. Nothing short of a rebuild or replacement will stop that, and the only question is whether that failure is going to be inconvenient, or a real problem. Next week in calm waters, or ten years from now offshore. Either way, it is coming, sorry to say.
hellosailor is offline
Shameless plug bljones General Discussion (sailing related) 327 12-24-2015 10:59 PM
Stuck Oil Plug - Ugh Michael K Gear & Maintenance 5 10-03-2009 08:24 PM
Plug Becky115 Gear & Maintenance 2 07-28-2009 02:18 PM
30 a plug motion300 Gear & Maintenance 4 02-16-2009 12:24 PM
Thru Hull Plug? Tree Gear & Maintenance 1 02-23-2006 07:35 AM
