Saildrive 280 Gearbox Removal - SailNet Community
post #1 of 1 Old 04-08-2012 Thread Starter
We have a 1980 S2 8.0B that has the 9.9HP Honda powered Saildrive 280 in place of the original OMC Zephyr (replaced by the previous owner). After sailing her a couple of seasons problem-free, I'd like to service the water pump/impeller and inner zinc anode. Trying to drop the gearbox/lower unit, after removing the 4 bolts, the gearbox drops about 2 inches, but that's it (photo). It seems to be hung up somewhere above. My guess is the gear shift linkage, as it will not pull through the nylon bearing at the engine mounting plate (photo).
Is the trick here to detach the gear shift linkage inside the extension housing? Looks like a threaded coupling just above the bend in the gearbox shift rod that's not easy to get at. Probably need to get a 10mm crowfoot wrench to be able to turn it.
Of course, the owner's manual offers little help here, stating simply that the gear housing is removed to service the inner anode & water pump impeller.
I'm curious to know what else might get in the way of completing this relatively simple (at first glance) job.
rafege is offline
Bristol 32 gearbox aailswor SailNet FAQ 4 11-30-2011 10:54 AM
Noisy Gearbox................??? yohoho Gear & Maintenance 8 01-29-2010 07:39 AM
OMC Saildrive Removal Tench745 Gear & Maintenance 4 04-02-2009 08:36 PM
Gearbox problemo......HELP ! bettyswollocks Gear & Maintenance 14 06-26-2008 02:37 AM
gearbox ratio dhornsey Gear & Maintenance 1 04-21-2008 11:07 PM
