Seemed Like a Good Idea... - SailNet Community
post #1 of 12 Old 04-08-2012 Thread Starter
Superior Sailor
Squidd's Avatar
Had to replace the depth finder as the one that came with the boat was non functional (Fish Finder Screen.. deteriorated in sun)
So I got a nice Hummingbird 600' depth finder with alarms..
When setting in the transducer I noticed this "contraption" holding the unit...
It's a bucket mounted to the hull of the boat filled partially with water...Tucked under port settee...
The transducer is mounted on a hinge with some stainless brackets and will "tilt" or lean when the boat "heels"...Keeping the transducer pointed directly at the bottom rather than off ot one side..and in the water for good transmission/penetration...
Seems like a good Idea so I restored it...
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is offline
post #2 of 12 Old 04-08-2012
Somewhat Senior Member
mgmhead's Avatar
Re: Seemed Like a Good Idea...
OMG! What about a bucket penetrating your hull sounds like a 'good idea'?
s/v Rhythm
Catalina 387 #29
Rock Hall, MD
mgmhead is offline
post #3 of 12 Old 04-08-2012
bljones's Avatar
It's not.
It's 5 o'clock somewhere:
bljones is offline
post #4 of 12 Old 04-08-2012
bljones's Avatar
Penetrating, that is.
Kinda ingenious. Always gives you real time depth.
bljones is offline
post #5 of 12 Old 04-08-2012
Mobnets's Avatar
mgmhead:
I don't believe there is any hull penetration going on here. This appears to be one the many approaches that allow you not to penetrate the hull with a transducer. These are well-described.
Mobnets
1973 Paceship Chance 32/28 "Westwind'
Mobnets is offline
post #6 of 12 Old 04-08-2012
mgmhead's Avatar
Whew, my misunderstanding. I've just never seen such a set-up and only imagined the worst. Carry on an ignore my previous post.
s/v Rhythm
Catalina 387 #29
Rock Hall, MD
mgmhead is offline
post #7 of 12 Old 04-08-2012
Working for next Boat
MobiusALilBitTwisted's Avatar
Look at the Photo again, you can see the bucket was cut and glued in place , i have seen this done on a smaller scale with pvc fittings and cooking oil, in an out of the way place like under the V birth, this one you just need to fill the water check the gas and oil and go for it .
S/V
1985 Venture 25
Fl Gulf Coast
GrahamO
"Möbius,You need another drink. You are starting to make sense".
MobiusALilBitTwisted is offline
post #8 of 12 Old 04-09-2012
Battered and Bruised
Silvio's Avatar
Hey if it aint broke... and you like the results you get then go for it.
For what it is worth I have had very good results by mounting my fish finder in silicone and shooting through the hull. I have an actual thru hull depth finder that correlates the depth readings on the fish finder quite nicely. I used a similar set up to your bucket to locate a good mounting location for the fish finder transducer.
I don't know hat the effect of healing really makes that much of difference. The error from healing would be most pronounced in deep water when it would also be least important imho.
SV S.S.R.I
It's my happy pill
Silvio is offline
post #9 of 12 Old 04-09-2012
MikeOReilly's Avatar
My Grampian 34 (now for sale) has this kind of well built right into the inner hull. Looks original to me.
Works fine as long as your hull is solid. Saves having another hole in the boat. Good idea Squidd!
MikeOReilly is online now
post #10 of 12 Old 04-09-2012
72 C&C Corvette
CorvetteGuy's Avatar
buckets should be left for bailing or personal matters
CorvetteGuy is offline
Soft shackles a good idea? tenuki Gear & Maintenance 60 02-22-2012 03:48 AM
in a storm... good or bad idea to... jobi Learning to Sail 14 07-05-2010 04:58 PM
Who thought this was a good idea? flyingwelshman General Discussion (sailing related) 14 04-08-2010 07:19 AM
Shaving the hull, good idea? CapnRal Gear & Maintenance 11 02-06-2007 12:01 PM
a good food idea Tegolin Provisioning 1 06-25-2005 07:47 PM
