New thru hulls .. is this ok? - SailNet Community
 1Likes
post #1 of 28 Old 04-08-2012 Thread Starter
smp
C&C 32
smp's Avatar
Send a message via MSN to smp
Hi all. My C&C 32 has (had) flush thru hulls. The flange on them was very wide (over 2.5 inches for .75" thru hulls), the flange was about 3/16" thick and hull was recessed to accommodate them. I have had no luck sourcing replacements. The fibreglass did not have any gelcoat over it or anything in the recess so I went ahead and put a layer of epoxy down as a kind of barrier coat.
Now, I could fill and fair the recesses but I'm concerned that I won't do a good job of it having never done any fibreglass or epoxy work before this. Is there anything wrong with leaving them as is? See pics below, that's the new thru hull sitting in the recessed cavity. I would of course be using some sealant when installing this for real, that's just a dry fit.
What do you folks think?
The white area of course is the recessed section. Again, it's about 3/16" deep. The hull is solid and pretty thick in this area.
smp is offline
post #2 of 28 Old 04-09-2012
DrB
Re: New thru hulls .. is this ok?
PERKO Thruhull at West Marine
Here is flush mounted thru-hull. Don't know if it is the right size, but there are many.
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
post #3 of 28 Old 04-09-2012
EJO
Dutchman
EJO's Avatar
I wouldn't like the exposed side of gel/fiberglass coat. I also assume that this would slow the boat down with the eddies these "imperfections" create. Find out what the original ones were and replace equal. DrB gave you a link. Bottom line I would not keep it as in the pictures.
Skipper E-J
S/V "Sailmates" 1973 IRWIN 32 Classic
I want to live and sail forever, so far so good[/SIGPIC]
EJO is offline
post #4 of 28 Old 04-09-2012
Senior Moment Member
SloopJonB's Avatar
Check the C&C site on the net - they have links to the old suppliers as well as an outfit that carries proprietary C&C stuff.
C&C Yachts - C&C Photo Album & Resource Center
If you can't find equal replacements, you MUST glass over the conical depressions.
SloopJonB is offline
post #5 of 28 Old 04-09-2012 Thread Starter
smp
C&C 32
smp's Avatar
Those perko ones aren't the right size. I have looked, and I have checked with the C&C mailing list and the site. The closest I got were ones from buck algonquin but they were no good either.
I guess I'll just glass over it, fair and redrill. Either that or mix up some thickened eqoxy, stick the thru-hull in until flush with the hull, scrape away any excess and tape some clear plastic sheet over to keep it flush. I hear about "mold release wax", is there a special type or any wax product will work?
Thanks
smp is offline
post #6 of 28 Old 04-09-2012
Those look like Forespar Marelon thru hulls. I just replaced mine and they look identical to yours. The 3/4" flush thru hulls have an outside dia. of 2.43". Check out Forespar's website, has all the dimensions.
wm1999 is offline
post #7 of 28 Old 04-09-2012
72 C&C Corvette
CorvetteGuy's Avatar
If your into racing then I would fair it out, if not seal it , use it, and call it done. PHRF matters if you race and that would matter
CorvetteGuy is offline
post #8 of 28 Old 04-10-2012 Thread Starter
smp
C&C 32
smp's Avatar
Not sure where you saw marelon in those pictures .. maybe the white area? That's just exposed hull, raw fibreglass layup. Recesses were cut into hull when boat was made. I should post a picture of the thru-hulls I removed to give people an idea, they have a very wide flange and believe me, I've looked high and low for replacements and they don't exist. Someone at a local chandlery suggested that they were probably machined. I've considered marelon but I've decided to stick with bronze. If there is a marelon thru-hull that will fit flush I haven't found it.
smp is offline
post #9 of 28 Old 04-10-2012 Thread Starter
smp
C&C 32
smp's Avatar
I believe leaving it as is would be sound. But yeah, I'm not racing now but I believe I would like to down the road so this is good input. I may try my hand at fairing the recessed flush with the rest of the hull.
Mold release wax? Any wax or special product?
Thanks
smp is offline
post #10 of 28 Old 04-10-2012
DrB
Close Enough for the Government?
Boat Marine Plumbing Flush Head Threaded Thru Hull
Look at the dimensions of the Marelon Thru-Hull for the flush mounted 3/4" thru-hull. Flange is 2.43, which is pretty close to 2.5 inches that came out of the boat. If you are set on using bronze, then this is a moot point.
DrB
DrB is offline
2.5 hulls planzman Boat Review and Purchase Forum 4 07-18-2008 11:20 AM
Through-Hulls kwaltersmi Gear & Maintenance 3 08-29-2007 05:43 PM
GRP hulls radly53 Boat Review and Purchase Forum 4 03-20-2007 04:35 PM
Through-hulls Zanshin Gear & Maintenance 8 10-02-2006 06:54 AM
Through hulls drynoc Gear & Maintenance 5 08-14-2006 01:47 PM
