bronze cowl vents - SailNet Community
 3Likes
post #1 of 15 Old 04-08-2012 Thread Starter
amyspins
amyspins's Avatar
bronze cowl vents
besides the cost - any reason not to have them? The plastic white ones just don't seem to do the boat justice -
Newly Obsessed Neophyte
Iota H-28
amyspins is offline
post #2 of 15 Old 04-08-2012
Lake Superior Sailor's Avatar
Re: bronze cowl vents
I changed mine to chromed bronze they match my winches....Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #3 of 15 Old 04-08-2012
paulk's Avatar
Keeping them polished is a major chore. I spent a summer making a 1929 Elco "shipshape" every day, and by the time I'd finished shining everything once, it was not only lunchtime, but time to start over, too. A dull green patina develops eventually, even if they're laquered, unless you keep after them. They're also pretty heavy.
paulk is online now
post #4 of 15 Old 04-08-2012 Thread Starter
amyspins
amyspins's Avatar
thanks guys - sounds like one vote for and one against - but Paul, did you go back to plastic with all that said?
Iota H-28
amyspins is offline
post #5 of 15 Old 04-09-2012
chef2sail's Avatar
I have chrome vetus ones. No issues and look great. Sont require constant polishing. They are way more expensive though than the PVC ones.
I have a question? Why is mine red inside...some are white?
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #6 of 15 Old 04-09-2012
Senior Moment Member
SloopJonB's Avatar
Use cast bronze or spun brass cowls if you have a traditional style boat - clipper bow, schooner, Channel cutter etc. and don't mind either polishing them all the time or the green patina they acquire if left alone.
On a more modern boat, use stainless steel or cast aluminium.
Chromed ANYTHING has no place on a boat IMO - it will pit and peel for certain. Usually sooner rather than later as well.
Those cheap PVC ones have no place on ANY boat - the ultimate in tacky and they aren't even that cheap. They also don't move enough air to offset cutting a hole in your deck.
amyspins likes this.
SloopJonB is offline
post #7 of 15 Old 04-09-2012
SloopJonB's Avatar
I have a question? Why is mine red inside...some are white? Dave
Red is a traditional colour for the inside of them. I think they look very deluxe if the inside is painted the same as the hull or boot stripe colour.
rugosa likes this.
post #8 of 15 Old 04-09-2012
Tartan 27' owner
CalebD's Avatar
One reason to go with the softer plastic/rubberized ones is for the safety of the deck crew. If someone falls on a hard cowl vent it is going to hurt, a lot. Plastic, not so much.
I do agree that the metal ones may look nicer but they come with an extra helping of maintenance. The plastic ones look like Shrek's ears.
Everybody has one:
CalebD is offline
post #9 of 15 Old 04-09-2012
chef2sail's Avatar
On closer inspection my vetus dorades are stainless...not chrome
SloopJonB likes this.
Parkville, Maryland
Our blog-
post #10 of 15 Old 04-09-2012
SloopJonB's Avatar
Merely doubling the cost again will give you a nice stainless tubing guard for the vent and it will also double as a very nice grab bar for that flying crew.
Lets see - nasty PVC 4" cowl & plastic dorade ~$125
Beautiful S/S 4" cowl ~ $300, S/S tube protector ~ $300, Teak dorade box ~ $150 = $750
$750 VS $125 EACH - how can there be any question which you must have on your boat.
Just think - the typical Hinckley has 6 or 8 of them - $5 or $6K, just for deck ventilators. Helps to explain why their boats cost so much.
Cowl vents on 8.5M S-2 Frogwatch S2 1 03-10-2011 03:17 PM
B-27 Bilge Cowl Vent Size anoser Bristol 1 04-23-2010 08:52 AM
Dorade Cowl mdelmonaco Gear & Maintenance 10 02-02-2010 08:55 AM
S2 Cowl replacement maboyer S2 2 12-04-2007 10:44 AM
Cowl Vents annfer Gear & Maintenance 2 10-11-2002 02:08 PM
