Cracked Cockpit Sole - SailNet Community
post #1 of 16 Old 04-10-2012 Thread Starter
Hi All,
I had someone quote putting a teak sole in the cockpit of our 86 Catalina 30 the other day. He noticed a crack in the gel coat on the starboard side in the corner round that runs about 18" or so fore and aft down the corner. i have known about this and was planning to fix it with a gel coat repair kit but he felt it was a bigger problem and gave me contact information for a fiberglass guy who I called and is going to take a look at it this week.
It looks to me like flexing in the sole caused the cracking because there is nothing under it to support it, its just kind of like a bathtub if you will. I'm thinking mine is not the only boat that has seen this although I haven't read about it as a known problem with the C30. Has anyone seen this before? I will get some pics up as soon as I'm able.
Thanks
Joe
jetdrvr393 is offline
post #2 of 16 Old 04-10-2012
Tim R.'s Avatar
Re: Cracked Cockpit Sole
Is the FG guy his brother in law?
Probably just stress cracking in the gel-coat. Repairing just the gel-coat will not fix it as it will likely reappear. Check to make sure your cockpit sole core is intact. A surveyor who is impartial may be the best person to check this.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #3 of 16 Old 04-10-2012
Yes what happens is that the constant flexing eventually cracks the gelcoat. You can repair it by filling the crack, but it is likely to re-occur if you don't reinforce the area behind the crack to stiffen the structure.
You might take the view that it's taken 26 years to crack, so if it takes as long to re-crack after you fill it, that's not too bad.
If you do want to reinforce, you could do this yourself, if you feel so inclined. You'll reinforce under the corner with epoxy and fibreglass mat. Not too hard.
Casey's "Complete illustrated sailboat maintenance manual" covers this kind of repair in detail.
Some gelcoat cracking in a 26 year old sailboat at the points of highest stress is common and not too much to worry about, btw.
MarkSF is offline
post #4 of 16 Old 04-10-2012 Thread Starter
We bought the boat last August and the crack was there then. The surveyor found no issues with the cockpit so I feel pretty good about the core. The glass guy has been recomended by someone else other than the wood guy so ill see what he has to say.
From what I'm hearing here though Im feeling inclined to do it myself and fill the gel coat and reinforce with glass underneath.
The area below is the aft berth and would be hard for anyone to notice my handiwork if it comes out ugly
post #5 of 16 Old 04-10-2012
jimrafford's Avatar
You could also put down a product like NUTEAK and be done w/ it. I did our cockpit a year ago and it looks great.
Jim
S/V Deja Vu
CS 40
jimrafford is offline
post #6 of 16 Old 04-10-2012 Thread Starter
Jim
I saw that at the boat show this year but will it do anything for my fiberglass problem?
post #7 of 16 Old 04-10-2012
Senior Moment Member
SloopJonB's Avatar
Putting the teak down will stiffen the sole considerably.
SloopJonB is offline
post #8 of 16 Old 04-10-2012 Thread Starter
Agreed but I will still need to address the crack in the gelcoat. If I was going to put teak down could I get away with just filling the crack?
post #9 of 16 Old 04-11-2012
SloopJonB's Avatar
I'd simply bed the teak in thickened epoxy - no fasteners holes, no caulking, no plugs, levels the surface, seals cracks - what more could you want?
post #10 of 16 Old 04-12-2012
jimrafford's Avatar
Why do you think you need to repair the gelcoat crack.
Jim
S/V Deja Vu
CS 40
Dealing with a soggy cockpit sole Beersmith Gear & Maintenance 51 07-01-2011 12:16 AM
Cockpit sole repair 1965Columbia31 Gear & Maintenance 6 06-05-2011 06:18 PM
S2 cockpit sole core material timangiel S2 3 03-10-2011 03:47 PM
new core for cockpit sole Grcesq Gear & Maintenance 10 11-17-2009 05:18 PM
Is the cockpit sole cored? timangiel Gear & Maintenance 10 05-11-2007 10:32 AM
