Sump Pump Issue - SailNet Community
post #1 of 8 Old 04-10-2012 Thread Starter
Sump Pump Issue
Greetings all:
Recently picked up a Tartan 4100 and am still in the process of getting to know all her systems and ways.
Tested the sump pump a few weeks ago - all was OK. The pump is turned 'on' at the breaker, but will only operate when the float switch is activated. The sump collects shower water and fridge runoff.
Left town for about 2 weeks in March to find that the fridge deposited a good bit of water, so figured I could leave the sump switch on the breaker to 'on' while being away for my next stint, knowing that it would only operate when enough water sifted in. Tested it yesterday by dumping some water to well above the where the float switch should activate - no dice.
Questions:
1) When away from the boat for a while, is it a bad idea to leave the switch on at the breaker, even though the pump should only operate when there's water collected?
2) ideas to trouble shoot/fix.
Thanks in advance!
Neal
djangodog is offline
post #2 of 8 Old 04-10-2012
Re: Sump Pump Issue
Float switches do go bad.
It's fine to leave a bilge pump on, you only have to worry about battery charge. Parasitic loads on a battery will drain it, even if the pump isn't being activated. Is the boat at a slip, on a charger?
Jeanneau 54DS
Minnewaska is offline
post #3 of 8 Old 04-10-2012 Thread Starter
Re: Sump Pump Issue
Thanks - boat is at a slip under shore power, so there shouldn't be any power issues. Figured there'd be no harm leaving it on, unless float switch got stuck somehow and burned out the pump....
Sounds like the float switch could certainly be the issue here. I banged it a few times, with no result. Perhaps I'll take her apart and investigate from there....
post #4 of 8 Old 04-10-2012
Re: Sump Pump Issue
Push it all the way up with your finger, if the pump activates, the float is stuck. Still need to replace it, but you'll know the pump works. If you can get the wiring straight, you can jump the switch to see if the pump works too. Occasionally, a pump will have a manual switch or button on it too.
Jeanneau 54DS
post #5 of 8 Old 04-10-2012 Thread Starter
Re: Sump Pump Issue
I think it's a Rule float switch, where the float is encased - it should have a test feature, apart from my banging it with a hammer...
post #6 of 8 Old 04-10-2012
Re: Sump Pump Issue
Do you mean the float switch is integral to the pump, not a separate device? If so, get a new pump and separate float switch. The switches dump out more often than the pumps, no point having to replace both all the time.
Jeanneau 54DS
post #7 of 8 Old 04-10-2012 Thread Starter
Re: Sump Pump Issue
They are separate. I meant to say that the float itself is encased, so I can't test it with my finger per se. I think it's this one:
SeaChoice Automatic Float Switch -19431
post #8 of 8 Old 04-10-2012
St Anna's Avatar
Re: Sump Pump Issue
Obviously test you are getting a current to the pump, then I would suggest you replace it with your spare pump with seperate float. Then you can play with the dodgy pump until it works or you discard it. 2c
Alternatively the switch may be dodgy
St Anna is offline
Shower Sump Pump Bump Gear & Maintenance 10 10-16-2011 06:57 PM
Yanmar 2GM injection pump issue? kcford Diesel 10 05-03-2011 11:03 PM
Sump pump rjcaudle Gear & Maintenance 9 11-21-2010 09:34 PM
08 Beneteau 40 freezer sump pump nika44 Gear & Maintenance 4 04-14-2010 12:44 PM
Bilge pump issue JSailer Gear & Maintenance 22 01-05-2009 12:08 AM
