Loose motor mount - SailNet Community
post #1 of 3 Old 04-11-2012 Thread Starter
Loose motor mount
New to SailNet, please forgive if this has been discussed. One of the eight wood screws holding the engine in my Tartan 28 is loose. It appears to pass through the fiberglass into wood. The screw is fairly tight, but continues to turn with a few lbs pressure. Someone suggested placing wood slivers in the hole; others have suggested 3M products, but caution not to use anything that will prevent the screw from being withdrawn sometime down the road. Anyone had success with a similar situation?
Thanks,
Mike
mike1970 is offline
post #2 of 3 Old 04-11-2012
mitiempo's Avatar
Re: Loose motor mount
If the wood is dry I would put epoxy into the hole, let it soak in for a half hour, and then put thickened epoxy in before putting the screw back. It's easily removable in the future.
Brian
mitiempo is offline
post #3 of 3 Old 04-11-2012
celenoglu's Avatar
Make sure the wood inside is still in good condition before attempting any repairs.
celenoglu is offline
Loose engine mount studs Bateau25 Newport 6 02-16-2011 08:55 PM
i need to add a motor mount...how hard is it? mountforever Gear & Maintenance 6 07-09-2009 12:10 PM
Bent Motor Mount brrit Gear & Maintenance 1 11-12-2007 10:47 AM
motor mount help hubbardsw Gear & Maintenance 1 11-12-2007 09:07 AM
outboard Motor Mount reid5009 Gear & Maintenance 3 04-12-2003 08:29 PM
