alcohol stove - Page 2 - SailNet Community
post #11 of 19 Old 12-15-2003 Thread Starter
alcohol stove
I hate to give up the oven. My wife and ONLY mate wants to bake something in it so I have to come up with a fix thanks for thoughts
KenD is offline
post #12 of 19 Old 12-15-2003
alcohol stove
Does anyone use a diesel stove/oven? I''ve heard good things about them, but I''m don''t know if they produce enough heat to cook well. I''d rather use one fuel. And I noticed one boat that had a diesel stove/oven in it and then a propane cook top. I always supposed it cooked better than the diesel.
Chas
flicker is offline
post #13 of 19 Old 12-16-2003
alcohol stove
Ken, Origo does make an oven that fits below the 2 burner stove. Not cheap.
williamjchampion is offline
post #14 of 19 Old 12-17-2003 Thread Starter
alcohol stove
Neither is keeping a sailboat, or come to think about it a wife.Chrismas is comming may be a merry christmas to me present.
KenD is offline
post #15 of 19 Old 11-10-2009
Thanks for spamming us Mike...
sailingdog is offline
post #16 of 19 Old 11-10-2009
xsboats's Avatar
Alcohol is for cooks, not cooking. You need a pressure cooker to compensate for the lack of btu's, extra firefighting equipment for the flare-ups, and a gas mask for the fumes.
xsboats is offline
post #17 of 19 Old 11-10-2009
No flareups with an Origo because they arent pressurized. No moving parts to break and alcohol wont collect in the bilge and blow up because it evaporates. Small price to pay for a little bit longer to boil water. I would never have a pressurized alcohol stove but I like my Origo.
sck5 is offline
post #18 of 19 Old 11-10-2009
I guess the mods nuked MIKE...
post #19 of 19 Old 11-12-2009
Cal 9.2 SilverSwan
roline's Avatar
6 of one, 1/2 dozen of the other. We all will have unique requirements and desires and in some cases, we might even need to compromise. I replaced the Kenon pressurized alcohol stove with a Force 10 2 burner with broiler. Would have preferred the oven for functionality , but did not want to give up the stowage space. I ended up with more storage by making a slide out shelf with a stowage box behind the stove in what was waisted space. Propane needs a controller with leak sniffers, tank containment locker and a good grade hi pressure connect hose.
For more info. check out the link below:
Stove
Cal 9.2 #19 SilverSwan
roline is offline
Hillerange Alcohol Stove Fittings halyardz Gear & Maintenance 22 04-08-2013 06:17 PM
Galley Maid Alcohol tank windydays Gear & Maintenance 7 08-24-2010 04:59 PM
Perko alcohol stove -- help! grey99 Gear & Maintenance 7 10-06-2009 02:51 AM
Need info on Pearson 30 alcohol stove pilot2sailor Gear & Maintenance 3 01-08-2004 01:01 PM
conversion gas stove? nauticalrich General Discussion (sailing related) 7 02-27-2002 05:17 PM
