Dripping Stuffing Box - SailNet Community
 3Likes
post #1 of 30 Old 04-11-2012 Thread Starter
I have an '85 Catalina 30. The stuffing box drips 3 to 4 drips per minute whild in port and not running. Some of my neighbors say it should not drip at all while stopped and others say it's not a problem. Just trying to get a consensus as I dont want to haul the boat to fix.
jahjammin is offline
post #2 of 30 Old 04-11-2012
johnnyquest37's Avatar
re: Dripping Stuffing Box
It should not drip at all when the shaft is not turning. When turning, it should 2-4 drips per mimnute. What is yours doing when the shaft is turning?
Here is an article on servicing the stuffing box. Service Your Stuffing Box | Cruising World
All this assumes that you do not have a "dripless" gland, which should not drip at all.
[/B]S/V Wind Orchid
Catalina 350 (hull# 273)
Annapolis, MD
LET'S GET SERIOUS ABOUT REMOVING POLITCAL TAG LINES -- NOW!
johnnyquest37 is offline
post #3 of 30 Old 04-11-2012
Courtney the Dancer
jrd22's Avatar
IIRC, with some of the new packing materials (graphite?) they don't even need to drip while in gear. I agree that it should not drip (much) while in neutral. You should be able to just tighten the nut up a bit, but make sure it still drips when moving, better to have a slight drip in neutral than no drip (heat) in gear, sometimes it's a fine line.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #4 of 30 Old 04-11-2012
All of the packing materials, except the dripless glands should drip a little while the shaft is turning. All should stop dripping when stopped. If it drips when stopped and you are away a couple of weeks, and the power fails, your boat will sink.
I recommend you fix it. try tightening a little, if you haven't repacked in a couple of years, repack it. It's not that hard. ( I had great luck with graphite packing).
The Sun has Risen on a New Day filled with the Promise of Adventure.
CapnBilll is offline
post #5 of 30 Old 04-11-2012
jj, it is time to tighten the box or repack it.
If it needs repacking I'd suggest GoreTex, which will allow you to have zero leaking while not underway and very little when running. And lasts a very long time.
hellosailor is offline
post #6 of 30 Old 04-11-2012
mitiempo's Avatar
Here is another link that explains how to repack the stuffing box. Best I have seen. Re-Packing A Traditional Stuffing Box Photo Gallery by Compass Marine at pbase.com
As posted it should only drip when the shaft is turning, and depending on packing material possibly not even then.
Brian
mitiempo is offline
post #7 of 30 Old 04-11-2012
snake charmer, cat herder
zeehag's Avatar
mine was peeing like a bunch of kids hanging out on the corner-after a case of beer-- that was underway as well as moored--we stuffed it and we stuffed and adjusted it-- still was a lil sinky-- now isnt as bad--only dripping -- i used gore-tex on both my rudder and my shaft packing glands with decent success-- rudder is totally dry now and prop shaft is still drippy, but not sinky....remember to make sure the stufffing box is packed before installing, if it is a flanged unit, like mine. makes a difference in leakage.
formosa 41, cruising tropics
zeehag is offline
post #8 of 30 Old 04-11-2012
casey1999's Avatar
Mine also drips (1 drip every 10 seconds) at the dock. I will try to repack but the box is in poor shape so afraid to touch it. Plan to dry dock in coulple years at which time I will pull shaft and install new box and hose and install new engine mounts. Also will inspect prop shaft.
My understanding is even with new packing your seal could leak at the dock if the shaft is scored or grooved. Your dirp rate not only depends on your packing, but also shaft condition. If the shaft is in poor shape, you may have excess leak rate.
Also, eveything I read says you should have a drip when the shaft is turning- this is how the seal is cooled and lubricated. The only seal that should not drip is a mechanical type- they have no packing.
casey1999 is offline
post #9 of 30 Old 04-11-2012
The most female moderator
Donna_F's Avatar
Dock
It's in such a shape that you're afraid to touch it but you're leaving it for a couple years?
jrd22, chef2sail and mitiempo like this.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #10 of 30 Old 04-11-2012
Seņor Member
PorFin's Avatar
Casey,
With respect, I think you may be heading for a fall. If the box is that suspect, I'd be worrying my rear off whenever I went out under power. If you hit a deadhead or get a warp around the prop, it could be enough to cause the box to fail and then you're gonna be in a world of hurt.
I'm thinking that the place to find out for sure whether or not the box is serviceable will be somewhere close to a TravelLift, and not out in a deep channel.
Just food for thought...
PorFin is offline
Fresh water tank vent 'dripping noise' sandycohen Gear & Maintenance 0 07-21-2011 12:51 PM
Dripless Packing seal is Dripping Valmika Gear & Maintenance 7 04-23-2011 10:55 PM
Dripping Wet Cave Lockers tager Living Aboard 3 05-13-2009 07:23 PM
Oil dripping over the side ? t4li3sin Seamanship & Navigation 13 05-01-2009 02:41 PM
Problem Seacock -dripping. Is this abig deal? Pamlicotraveler Gear & Maintenance 32 07-02-2008 01:14 AM
