Inspecting forestay under Hood SeaFurl 3250 Reefer Furler - SailNet Community
post #1 of 3 Old 04-11-2012 Thread Starter
casey1999's Avatar
Does any one know if I need to take my Hood SeaFurl 3250 compeletely apart to see the Norse fitting on the base of the forestay wire?
I have the instrictions and it looks like I would need to remove the drum and foils off the forestay to see the fitting. I want to inspect the forestay wire and fitting for wear and corrosion/cracking.
casey1999 is offline
post #2 of 3 Old 04-11-2012
Question Re: Inspecting forestay under Hood SeaFurl 3250 Reefer Furler
You might be best off just looking at the install date and then arbitrarily replacing the stay if it's been up over a decade. (Warmer salt water climate in HI)
On second thought , that's not really what you were asking, but that's the internet for ya!
(I have a Harken furler; so have no experience with SeaFurl.)
Best,
LB
olson34 is offline
post #3 of 3 Old 04-11-2012 Thread Starter
casey1999's Avatar
Best,
LB
Yes. I plan to replace all standing rigging and chainplates in two years. Even after that I would like to inspect the forestay Norse fitting at least every year thereafter.
Forestay adjustment with Hood drum roller furler Nilaya Gear & Maintenance 8 05-17-2015 12:57 PM
Hood Seafurl jerry430 Gear & Maintenance 3 07-19-2009 02:30 PM
Need help Reassembling Hood Seafurl 810 chris1514 Gear & Maintenance 1 06-24-2009 02:25 PM
Hood Seafurl Maintenance torlowski Gear & Maintenance 6 06-23-2008 05:43 PM
Line on Hood Seafurl 3250 jr438234606 Gear & Maintenance 4 03-26-2008 12:23 PM
