straightening bent anchor roller - SailNet Community
post #1 of 14 Old 04-11-2012 Thread Starter
Two years ago we bumped the wood pilings of a fishing dock and the anchor (which hit first) twisted sideways and bent the stainless steel flange holding the bow roller. [I don't know why we didn't just anchor then bleed the fuel line
and dock under power instead of trying to dock under sail.]
I'd like to bend it back. Anyone have suggestions on how to do this while its on the boat?
extremo is offline
post #2 of 14 Old 04-11-2012
overbored's Avatar
Re: straightening bent anchor roller
pictures would help . hard to advice without them. but I do know it takes more force to straighten then it did to bend it. if it is stainless the bend will work harden and will not want to bend back as easy as the rest of the part. most times they need to be removed to be straightened properly.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #3 of 14 Old 04-11-2012
Senior Moment Member
SloopJonB's Avatar
Your fasteners and mounting system have already taken a huge amount of abuse. Dismount it, get it straightened properly and remount it with new fasteners.
I know that the lack of access inside usually makes it a rotten job to get the nuts off but that's why God made small people!
You may find hidden damage you are unaware of when it is off as well.
SloopJonB is offline
post #4 of 14 Old 04-12-2012
Originally Posted by Chris12345 View Post
Now after you heard all the cautious advice, here mine:
Assuming the flange is flat metal: You take an adjustable pipe wrench, or a large adjustable wrench, and grip the stainless with it. Use some thin hard plastic or hardwood to prevent deep scratches.
If needed, you can put a pipe over the handle of the wrench for more purchase.
Also, you can use two wrenches, one holding, one bending, to avoid putting excessive load on the fasteners.
If it was bent a lot, it might crack when you bend it back. But then, if that happens, the part was pretty much done already anyways.
This is the classic BFFI approach and is sure to eventually cost ten times the other methods described above.
Plus you will surely hurt yourself when you try it.
John
ccriders is offline
post #5 of 14 Old 04-12-2012
..........huh?..
Izzy1414's Avatar
John
It's hard to make this assessment without seeing it. It all depends on how badly it's bent and the access to it, and whether you can do it without risking further damage as SJB warns. I have had fairly good luck straightening things as long as there hasn't too much distortion in the material. The key is to try to exactly duplicate the incident that bent it, only in reverse, and in a slow and controlled manner. That means the stationary end should be held steady to take the pressure off the mounting bolts if you're able to leave it on the boat or bolt it down down to something solid if you have to take it off. Then slowly apply the force in exactly the opposite direction that bent it from the same point that hit the dock. Stop several times in the process to make sure that flanges are straightening instead of kinking. I have found crescent (adjustable) wrenches highly useful in the process of slowly helping flanges back into shape. Sometimes the hardest part of straightening something in place is having the room to over bend the piece because you almost always have to bend it past its original shape so it can spring back into shape. I would discourage using heat if at all possible because it will lead to more distortion, besides being downright dangerous if you're able to leave it on the boat.
S/V Boccata d'Aria
I'm not sure what Dickens are, but I think they may be important and I sure as hell don't want them scared out of me.......Izzy
Izzy1414 is offline
post #6 of 14 Old 04-12-2012
After seeing many such bent bow rollers made out of 1/4 inch stainless, I started building them out of half inch stainless plate.
You can put a length of pipe on your pipe wrench for more leverage .
Brent Swain is offline
post #7 of 14 Old 04-13-2012
Old as Dirt!
svHyLyte's Avatar
Extremo--
A few years ago we had exactly the same experience when docking on a windy day at the St. Pete YC. One of the harbor master's assistants could have reached out and fended our bow pulpit, as I expected, but instead he simply stood there and watched the fluke of our port anchor catch the corner of a fender piling and bend the heck out of the side-plate on the bow roller before a chunk of the piling was ripped off.
I went through many of the exercises described here by others during the subsequent weekend to ensure we had a usable roller when we continued our trip the following Monday. The rebent roller "kind'a" worked, well enough that we didn't need to interrupt our trip, but, in the end, to really get a usable roller that functioned properly, we had to replace the damaged one. We ended up with a unit made by Kingston that was designed for our CQR that was relatively inexpensive although a terrific pain in the neck--literally and figuratively--to mount, but it was the only real solution. If one is going to do something one might as well do it right the first time, no?
FWIW...
svHyLyte is offline
post #8 of 14 Old 04-13-2012
CapnBones's Avatar
What size boats are you putting such thick plate on? I am building a roller for my 30' boat and I had thought 1/4" would be more than enough, but I only want to do this once so any experience would be greatly appreciated.
Thanks
CapnBones is offline
post #9 of 14 Old 04-13-2012
CapnBones's Avatar
Point taken... Not that I hit things...
post #10 of 14 Old 04-13-2012
Actually no, that totally depends on how the thing is bent.
If the position of the bend lends itself to proper counter-holding with a second wrench, it can be done cleanly, and as good as by taking the whole thing off.
IF that is the case we could only tell with pictures, not speculations.
I leave that to the owner of the bow roller to judge.
If one would hurt himself trying, or break stuff, depends mainly on how dumb he is; you told what you think would happen to you; others might have different experiences.
Okay, I'm trying to visualize how you are going to do this. Boats in the slip, bow in. You are on the dock? On the bow? Getting two wrenches, with cheater bar? Applying force at just the right angle to straighten a "U" shapped piece of stainless steel? Maybe a better approach is to have at a piling in exactly the opposite direction at a moderately sustained just right force? And still you've not looked for latent damage to the deck, deck core and fastenings; setting yourself up for water intrusion into the deck core and all the wonderful things that leads to.
The two wrench approach will only result in stress risers and work hardened metal within piece. The bow roller will be significanly weakened and will bend much more easily on the next event. Using a mandrel and roller press is probably the only way to get this bow roller back into nearly new functionality.
And for what it is worth, I would not injur myself because I would not try to straighten a bow roller in place no matter the degree of distortion.
John
No grins.
ccriders is offline
Tags
anchor roller , straightening
Anchor roller nikonf3blue CS Yachts 1 04-02-2010 07:45 AM
Anchor roller Thor5101 Gear & Maintenance 5 06-08-2009 02:23 PM
Anchor Roller on bow cygnetOH Newport 5 12-23-2007 12:18 PM
anchor roller ThomasTralee Gear & Maintenance 1 04-16-2003 01:19 AM
anchor roller jimdafoe Gear & Maintenance 0 02-15-2002 05:52 PM
