Harken MKII service - SailNet Community
post #1 of 2 Old 04-12-2012 Thread Starter
wduncan50's Avatar
Harken MKII service
It's time to clean and service my Harken MKII roller furler and I can't seem to find much on the internet on how to do this. I currently have my head sail at a sailmakers shop getting restitched and I would like to grease the roller furler with McLube. Do I:
1. Remove the bolts from the torque tube and slide it up.
2. Slide up the track and hold both up with vice gripes.
3. Spray McLube down Roller Furler.
How much McLube should I use.
Will Duncan
wduncan50 is offline
post #2 of 2 Old 04-12-2012
Re: Harken MKII service
The Harken has Torlon (plastic) bearings. All you really need to do is to rinse the bearings with fresh water. Though using a dry lube certainly won't hurt anything.
It's a good idea to lift the torque tube if only to facilitate the rinsing and to make sure the fasteners aren't becoming corroded. Use Lanacote on the screws when reassembling.
Don't forget to rinse the bearings in the swivel too.
knothead is offline
Harken Traveller on a C&C 32 Kiltmadoc Gear & Maintenance 10 07-18-2010 05:47 PM
Harken MK II unit 1 ROSA Gear & Maintenance 15 06-12-2010 11:43 PM
Harken bat car system docrn Gear & Maintenance 0 08-03-2009 01:18 AM
Harken Magic Box mikehoyt Racing 5 07-11-2003 06:47 AM
Harken Headfoil NorthernDancer Gear & Maintenance 1 04-28-2003 05:54 PM
