Bottom Paint dilemma - Page 2 - SailNet Community
 9Likes
post #11 of 33 Old 04-12-2012 Thread Starter
sevseasail's Avatar
Re: Bottom Paint dilemma
Thank you all for pitching in...
OK, to answer some things.
I only have Sundays off, if I spend them working on the boat i wont be sailing on that day. if i need 4 days to do a bottom job that's one month of sailing out the window...
What's holding me right now is the bottom paint. like I said, i don't want to have to launch and retrieve several times.
I though it would be more difficult of a job, now, with all of your support I'm building confidence and getting ideas on how to do it and it's looking more appealing by the minute.
I know what boat means..... Bring Out Another Thousand.... I know. That's why I have always sailed on friends' boats and never owned one, now i think I'm old enough to have one of my own and I accept the consequence$$$$...
Now, another question, if I were to put a barrier coat before the bottom paint, how much more work are we talking about?? Sanding to the gel coat plus X coats of barrier coat, plus 2, 3 coats of bottom paint.....
Thank you!!!!
sevseasail is offline
post #12 of 33 Old 04-12-2012
The most female moderator
Donna_F's Avatar
Dock
Thank you!!!!
I think you're making it more difficult than it has to be. sand and paint and get the boat in the water. Leave the barrier coat for the off-season when you can't sail.
Familycruisers likes this.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #13 of 33 Old 04-12-2012
I just did a barrier coat on my 25`er , thats a bigger job ..
i would scuff it then paint , then if you could get a hour on the lift to touch up what was missed ,and have them drop it in ..
seems the fastest way ..
if your going to strip it completly and do a barrier coat ..that might be worth a $1000 labor :/
and let the yard do it .
good luck !
Sunday Driver is offline
post #14 of 33 Old 04-12-2012
DrB
How old is the boat? What was it history before you...
If the boat is many, many years old and the boat previously was left in the water over the summer and it hasn't blistered, the likelihood that it will blister now is very low, so I wouldn't barrier coat it at all if that is the case.
That being said, if you want to barrier coat it, do in the off season as you will need to blast/sand away all the paint and you will need to let the bottom full dry of any trapped moisture, else the barrier coat is useless.
So moving forward:
Wake up early on your free Sunday, tape it and wet sand/scotchbrite it and wet rag it to remove the dust. Allow it to dry while you drink a cup of coffee and suit up for painting, paint it, clean-up, have breakfast, drive to the water, launch it and paint the few places that were covered by the trailer during the launch and sail it for the rest of the day. Easy Peasy.
End of Season, get boat. Decide if you want to barrier coat it then.
sevseasail and Familycruisers like this.
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
post #15 of 33 Old 04-12-2012 Thread Starter
sevseasail's Avatar
Now you're getting to know me....
I think it might had some blisters in the past, look at the pictures and tell me what you think....
So moving forward:
That sounds very good to me, we'll see how it goes; according to your schedule I should be at the ramp at 11:00am.... we'll see.........
post #16 of 33 Old 04-12-2012
Dirt Free
boatpoker's Avatar
The price you originally quoted is ludicrous. Who cares if the power boat guys don't know what a Catalina is . An FRP bottom is an FRP bottom whether its power or sail. If you really don't want to do it yourself get a quote from them ..... we're not all bad
PS. No one can give an accurate quote without seeing the bottom.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is offline
post #17 of 33 Old 04-12-2012
Skipper Jer's Avatar
$200 for paint and a grand for labor. If you were closer to me I'd come over and paint the bottom. Wouldn't mind making about $500 an hour.
Skipper Jer is offline
post #18 of 33 Old 04-13-2012 Thread Starter
sevseasail's Avatar
For what I gather out of all the appreciated input from you guys that have done the job, I recon nobody is spending a great deal of time sanding, which was my main concern; we all know applying paint to 150 SqFt is not a real task.
So, I have decided.
Today I'm working from home, on my lunch hour I will do the sanding (I already have all the necessary things for that) and the tomorrow i go buy the paint and apply on Sunday.
I'll keep you all posted. Thank you sooo much for all your responses !!!!
post #19 of 33 Old 04-13-2012
all you want to do is scuff it so the paint sticks ,
i use a drywall sanding attachment 3"x8" at the end of a pole ..
you could also get a tarp big enough to cover the ground 20 x10 (harborFreight.com)has cheap ones .
lay it out , then back the trailer over it .
post #20 of 33 Old 04-13-2012
Sailpappy
sailpappy's Avatar
Send a message via MSN to sailpappy Send a message via Skype™ to sailpappy
You need to purchase the antifouling bottom paint and read the directions, most recommend that the boat goes into the water no longer than 6 hours after the paint is applied, the price you were quoted is out ragious, hire a local painter and the bottom paint as well as a tarp to put under the boat so you don't get any messy after affect from the job. After the inital open area is done, just block the stern up high and lower the trailer to expose the spots that are covered by the pads on the trailer. but I wouldn't paint it before a day before launch.
John Cal-36
sailpappy is offline
Don Casey: Paint Waterline Stripe with Bottom Paint asdf38 Gear & Maintenance 23 03-05-2016 06:50 PM
Bottom paint prep, chipped paint josrulz Gear & Maintenance 16 02-14-2010 08:24 PM
Bottom Paint ?? mikeandmarysail Gear & Maintenance 10 02-28-2007 02:12 PM
bottom paint flyingdiva Gear & Maintenance 4 02-13-2005 11:40 AM
Bottom paint TADIAS Gear & Maintenance 5 01-20-2005 02:28 PM
