Bottom Paint dilemma - Page 3 - SailNet Community
 9Likes
post #21 of 33 Old 04-13-2012 Thread Starter
sevseasail's Avatar
Re: Bottom Paint dilemma
Originally Posted by Sunday Driver View Post
all you want to do is scuff it so the paint sticks
you could also get a tarp big enough to cover the ground 20 x10 (harborFreight.com)has cheap ones .
lay it out , then back the trailer over it .
Thank you!!
Originally Posted by sailpappy View Post
most recommend that the boat goes into the water no longer than 6 hours after the paint is applied, After the inital open area is done, just block the stern up high and lower the trailer to expose the spots that are covered by the pads on the trailer. but I wouldn't paint it before a day before launch.
John Cal-36
Thanks, I read about blocking the boat up sot of like the way you describe...
Can I apply one coat on Saturday night and then one more on Sunday before it goes in the water?
sevseasail is offline
post #22 of 33 Old 04-13-2012
The most female moderator
Donna_F's Avatar
Dock
Originally Posted by sevseasail View Post
Thank you!!
You'll probably only need one coat.
Stop it!
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #23 of 33 Old 04-13-2012
Skipper Jer's Avatar
So, what kind of paint are you going to apply, ablative or hard?
Skipper Jer is offline
post #24 of 33 Old 04-13-2012
DrB
You need to purchase the antifouling bottom paint and read the directions, most recommend that the boat goes into the water no longer than 6 hours after the paint is applied,
John Cal-36
Disagree. All paints that I have used allow up to 30 days for fresh paint. Longer than that you need to "scuff" it again.
Sevseasail - I wouldn't dry sand it. Use a scotchbright pad or wet sand paper. Place a plastic tarp under the area that you are working. Soak the scotchbright pad in bucket of water, scour area, rinse in same water. When bottom has been fully scoured. Get another bucket of clean water and a cloth rag. Wet rage, wipe down bottom to remove loose material, wring rag into bucket, and redo.
Allow water buckets to stand for a few days to allow paint/dirt to settle, then carefully decant clear water off, collect wet sediment, and dispose in accordance with local laws.
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
post #25 of 33 Old 04-13-2012
4KSB driver.
SHNOOL's Avatar
Um, probably just me, but I put 2 coats of VC-17m (freshwater for me)... but it took me about 4 hours to do. Sanding, add another 4 hours or so, and 20-30 minutes between coats (I did 2).
Here's a before
and after:
I don't have movable bunk boards, so I had to jack the boat up under the keel (fun).
SHNOOL is offline
post #26 of 33 Old 04-13-2012
Donna_F's Avatar
Dock
Nice job, schnool!
I don't think anyone's implying that you can't spend more time on painting the bottom, but the OP said that he barely had time to sail so we were pointing out that you don't necessarily have to spend a lot of time on it.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #27 of 33 Old 04-13-2012
Barquito
Barquito's Avatar
I don't think you will be able to paint under the bunk boards as you launch. The bottom is pretty much submerged b/f the boat floats off the bunks. You can lower the nose as much as possible (even into a hole in the gound), brace the stern, then raise the whole boat off the bunks by raising the nose again. Or just skip the areas under the bunks. Or, depending on your trailer, paint, launch, then float the boat back onto the trailer heeled over just enough to expose those areas under the bunks (it will look stupid, but, whatever). BTW, the cost of owning a trailerable boat can be reduced a lot if you are willing to have it in the driveway for parts of the year.
Valiant 32
Barquito is offline
post #28 of 33 Old 04-13-2012 Thread Starter
sevseasail's Avatar
Thank you, thank you, thank you to all of you...
Here's the update. I did sand today, used one of those sponge sanding blocks for drywall (100 grit) sanded with a bucket of water and rinsed with the hose. After that, I wiped the bottom with paint thinner as per paint instructions. After work I went to Worst Marine (only store in the area that will sell me bottom paint, all others only do it if I let them do the job. Yes, there are other stores that can get the paint but will have to order...) I went with Pettite Vivid as it was the only thing they had that will allow me to launch within 60 days and recoat after 4 hrs.
Have one coat on her already...... It took me about 1,5 Hr to get it sanded and cleaned and about 45min to put the first coat.
Almost there....!!!!
post #29 of 33 Old 04-13-2012
Pictures Mon, we need pictures!
post #30 of 33 Old 04-19-2012 Thread Starter
sevseasail's Avatar
OK, here she is with 2 coats on her, unfortunately could not launch on Sunday because the paint requires a 16 Hr before launching, also there are other issues, as the insurance which I'm trying to resolve today. Got a couple of quotes from BoatUs and waiting for my local agent to come up with something. (I would like to see what kind of coverage he can offer....)
She's looking better and better every day ....
Don Casey: Paint Waterline Stripe with Bottom Paint asdf38 Gear & Maintenance 23 03-05-2016 06:50 PM
Bottom paint prep, chipped paint josrulz Gear & Maintenance 16 02-14-2010 08:24 PM
Bottom Paint ?? mikeandmarysail Gear & Maintenance 10 02-28-2007 02:12 PM
bottom paint flyingdiva Gear & Maintenance 4 02-13-2005 11:40 AM
Bottom paint TADIAS Gear & Maintenance 5 01-20-2005 02:28 PM
