Epoxy on the prop? - Page 4 - SailNet Community
 9Likes
post #31 of 34 Old 04-19-2012
Re: Epoxy on the prop?
Minnewaska may have the best idea of all. If PYI takes care of their customers, they can certainly do what any good welding shop can do, and rebuild missing metal. Since there could be an issue per Lou452 of playing whack-a-mole if there are problems in the metal itself...again, PYI would be aware of that and who knows, they might just replace the blades as defective.
Certainly worth giving them a call & sending the prop in.
Lou452 likes this.
hellosailor is offline
post #32 of 34 Old 04-19-2012
sunfish?junior?
newportermike, You need to have some way for all of us gauge how good or bad your prop is. Maybe it is in fair shape? A picture with something for size to compare with like a ball pint pen, a metal rule with a scale. You might find a tire tread gauge. Anyway you can help someone determine how good or bad your prop is. You might try to clean it up with a 4" ss wire brush on 4" grinder. Make sure you wear eye protection!! a face shield long sleeve shirt and leather work gloves. The brush will spin at about 7500 rpm. In 30 min.time one little wire may fly out of the brush they can poke into your skin not bad if you have long sleeves WITH OUT EYE PROTECTION IT IS BAD ! You can find a cheap 4 inch grinder with a 5/8 shaft under 30 dollars. It will work like a champ. You can buy better ones also if you feel you will use it more with the right blades and wheels you can brush, cut, grind metal, stone, concrete. With the brush it will not remove metal. It will help make your prop clean to paint or epoxy. Good luck hope it works out for you !
Lou452 is offline
post #33 of 34 Old 04-19-2012
sunfish?junior?
Just read the two posting about PYI. I think I like the advice. I can weld any weldable alloy but even with my skill I recognize the men that do it day in and day out should be the best. I would send my prop to them. The balance issue could be the very big.
Lou452 is offline
post #34 of 34 Old 04-20-2012
sailguy40's Avatar
Originally Posted by asdf38 View Post
In general he's talking about some form of epoxy two part coating. Similar to a paint but probably more robust. I don't know what product exactly he might be referring too but I think people here will be able to help.
I wanted to note that the use of the word epoxy has also confused the crap out of me for a while. Prior to boating epoxy was a two part adhesive to me. But it's also a paint and a structural filler. I find it disappointing when the word is used by itself without specifying the type of product.
Even the great books like Don Casey say "fill it with epoxy" - well the 5 minute loctite epoxy at the hardware store? What are you talking about? I was aware that west marine sold west systems (not related) products by the (expensive) gallon but didn't know exactly what to make of it. Having learned a lot more and finally having bought some west 105 (general purpose resin) and 205 (hardener) I finally understand that yes, west epoxy is a sort of do it all solution for filling, bonding fairing etc.
I certainly agree with this. They say use epoxy but no one ever clarifies which of the many to use for the job at hand.
sailguy40 is offline
Feathering Prop vs. Fixed Blade Prop Benevento Pacific Seacraft 70 02-11-2011 08:52 AM
New Prop & Shaft - install prop questions preservedkillick Gear & Maintenance 2 05-22-2010 09:46 AM
Zincs for Sail Prop feathering prop jrbarn Gear & Maintenance 4 09-20-2006 11:40 AM
