Loose Footed Mains - SailNet Community
 8Likes
post #1 of 30 Old 04-13-2012 Thread Starter
Windkiller's Avatar
Loose Footed Mains
What's the word on Loose footed mainsails from those in the know?
I've read that they perform just as well for the most part
I saw one cheap and was thinking of picking it up
Windkiller is offline
post #2 of 30 Old 04-13-2012
Re: Loose Footed Mains
I have a loose footed main and my traveler is not at the end of the boom....about 2/3 back. I have no trouble with the main sheet or sail shape. The only thing I would recommend is that you have a good outhaul so you can adjust the foot easily. Most racing boats have loose footed mains.
Gary3675 is online now
post #3 of 30 Old 04-13-2012
I love my loose footed main. I feel like I get much better sail shape through the entire sail, expecially at the foot. The old footed mains lose a little shape at the foot at the boom attachment point (s) . ( like pleats ) I think the loose foot has especially helped my light-air performance.
Yes you need a good working outhaul, when you need to flatten the sail.
I would recommend the switch.
tempest is offline
post #4 of 30 Old 04-13-2012
tommays's Avatar
I have both types and IF there made correctly they both work fine
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #5 of 30 Old 04-13-2012
patrscoe's Avatar
Mainsail attached (slides or bolt rope) to the boom is much more forgiving then a loose foot main, if that's what you want but I much rather have a loose foot. With the proper outhaul set up, you will be able to really fine trim the lower portion of the main, and able to provide a nice chamber for light wind sailing. You will get a little more flutter with the loose foot. I also think the cunningham and outhaul controls work together well then a attached main.
Along with my halyards, cunningham and (1) reef row, my outhaul is run back to the cabin top to a large metal cam and winch.
Patrick
S2 11.0A 36'
Kinsale, Va
Tanzer 16'
Moseley, Va
patrscoe is offline
post #6 of 30 Old 04-13-2012
Junior member, rest old
msmith10's Avatar
I've had a loose-footed main for 4-5 years now, and I can't understand now why they haven't always been that way. I think you get a better and more easily controlled sail shape.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #7 of 30 Old 04-13-2012
jackdale's Avatar
Two advantages of an attached main
1) The shelf is a good indication of outhaul tension; too much causes a crease.
2) You can create a water collection system for rainwater.
jackdale is offline
post #8 of 30 Old 04-13-2012
rbrasi's Avatar
Could someone provide photo or diagram examples of this? I think it is applicable to my setup, but don't know enough about the terminology to say.
1968 Cal 2-30
Sandpiper 2
MDR
rbrasi is offline
post #9 of 30 Old 04-13-2012
jackdale's Avatar
jackdale is offline
post #10 of 30 Old 04-13-2012
As Jack's image shows the loose footed main is only attached by the tack and clew along the foot. There is no bolt rope or slides/slugs attaching the bottom of the sail along the length of the boom.
While this does eliminate the old 'shelf foot' which was intended to create something of an end plate effect, the camber of the sail is more properly uniform overall and generally the outhaul is more easily adjusted due to reduced friction.
On race boats it's a big help when you actually take the sail off and stow it below.. sliding a bolt rope foot sail out the boom is the hardest part.
Overall I don't think there's any compelling reason to go with anything but a loose foot, unless you're going to need the water collection aspect of the shelf foot..
chef2sail and patrscoe like this.
Faster is offline
Boom Bags and Loose Footed Main tdw Gear & Maintenance 5 03-10-2009 09:20 PM
Loose Footed Main tager Gear & Maintenance 3 03-02-2009 10:46 PM
Pros and Cons of Loose Footed Sails scurvy General Discussion (sailing related) 30 11-18-2006 10:12 PM
loose footed or track mainsail soverel28 Gear & Maintenance 5 05-21-2002 04:08 AM
Loose-Footed Mainsails SailNet Learning to Sail Articles 0 07-02-2001 08:00 PM
