Winch Maintenance and id - SailNet Community
 1Likes
post #1 of 14 Old 04-13-2012 Thread Starter
I am needing to take apart the attached winch to do maintance but have no idea what type of winch it is or how to disassemble. Any sugestions how to get it appart and what I should do to get it back in ship shape. Starting to grind a bit like it is dry or may have grit in it.
superiorvoyager is offline
post #2 of 14 Old 04-13-2012 Thread Starter
Re: Winch Maintenance and id
On closer examination today I was able to raise a name on the winch. It is Marinum. SO I have an ID but no idea how to disassemble it to grease it.
post #3 of 14 Old 04-13-2012
RhodesSwiftsure's Avatar
The end of the flat bladed winch handle should fit perfectly that horizontal slot you see when looking down into the winch. Using it like a huge screwdriver, you should be able to unscrew. Then the outer body will lift off. The prawl pushers/springs are usually contained, but you want to go nice and slow and maybe drape some towels around to catch anything that does manage to ping off.
Faster likes this.
"The slower we moved, the more we seemed to see."
- LP
RhodesSwiftsure is offline
post #4 of 14 Old 04-13-2012 Thread Starter
Great to Hear. I tried that Earlier but didn't move it and not knowing was afraid I might do Damage. Now that I know I'll go back down to the boat and try a little more "persuasion." Any suggestions on what type of grease to use?
post #5 of 14 Old 04-13-2012
Ditto above suggestions.
I would spray some AeroKroil or PBblaster into the top and allow to soak in before loosening. WD40 should work but I prefer the others.
I also tape a cardboard box with a slightly oversize hole in the bottom over the winch to keep all the parts in one place.
SJ34 is offline
post #6 of 14 Old 04-13-2012
Lewmar and Harken both make (repackage) grease for winches but ounce for ounce they're valued above gold. I would think just about any synthetic grease should work.
SJ34 is offline
post #7 of 14 Old 04-13-2012 Thread Starter
Took a little work but I got all the winches off and they are now in my shop soaking. The old grease was dry and caked but the gears all look good so probably just a good cleaning and repack them. When I have done winches in the past I always just grabbed what ever grease was lying around the shop so will probably do the same now. Any sailing stuff like specific grease I have to order in as there is nothing available locally (or within 1000km) so I try to find easily available alternatives. Thanks for the advice.
post #8 of 14 Old 04-13-2012
Senior Moment Member
SloopJonB's Avatar
I recommend white lithium grease - I currently have a cup of Gunk brand that is good. You can get it at auto parts stores in a cup like a chip dip cup.
By the way, marinium is the material the winch drums are made of, not the manufacturer.
SloopJonB is offline
post #9 of 14 Old 04-14-2012
Don't pack with grease, just cover all surfaces. A small disposable 1" brush is helpful. Clean with mineral spirits, doesn't take much soaking. Be sure to use waterproof grease if not using the right stuff.
Jeanneau 54DS
Minnewaska is offline
post #10 of 14 Old 04-14-2012
S/V Double Take
i have similar winches on my boat. Possibly, i will repeat, possibly they are Wilcox and Crittenden. They also used to make marine heads. You can google them, I think someone else is making parts.
1965 Oday Tempest #80
upei1 is offline
Winch Maintenance SawWhet Gear & Maintenance 1 03-21-2012 06:55 PM
Winch Maintenance CalypsoP35 Gear & Maintenance 7 01-02-2011 04:38 PM
winch maintenance VictorJ Gear & Maintenance 3 03-26-2010 05:54 AM
winch maintenance Loualfr Gear & Maintenance 12 03-27-2009 06:17 AM
Winch Handle Maintenance tdw Gear & Maintenance 9 10-23-2007 08:42 PM
