Mainsheet block chafing. - SailNet Community
 5Likes
  • 2 Post By mitiempo
  • 2 Post By SloopJonB
  • 1 Post By sailingfool
post #1 of 8 Old 04-14-2012 Thread Starter
davidpm's Avatar
The first picture is the big picture the second picture is a zoom in on something that doesn't look right to me.
I was thinking that just adding another shackle to one of the blocks will make it low enough to not cause a problem.
I'm surprised that it is like this as the setup does not seem new.
davidpm is offline
post #2 of 8 Old 04-14-2012
mitiempo's Avatar
Re: Mainsheet block chafing.
David
The first block should have a becket to attach the mainsheet to - someone took a shortcut.
Faster and SloopJonB like this.
Brian
mitiempo is offline
post #3 of 8 Old 04-14-2012
Senior Moment Member
SloopJonB's Avatar
If you don't want to pay for a new block with a becket as Miti correctly pointed out, it looks like you would get a more fair purchase by moving it to the forward padeye so it shares with the other block.
Would only take seconds to check it out.
Faster and davidpm like this.
SloopJonB is offline
post #4 of 8 Old 04-14-2012
ASA and PSIA Instructor
You might see if the straps can be moved in the groove of the boom, so the lines lead more fairly (position the block directly above the traveler)..
sailingfool is offline
post #5 of 8 Old 04-15-2012
Old as Dirt!
svHyLyte's Avatar
Originally Posted by mitiempo View Post
David
Mitiempo is correct. However, you can save the cost of replacing the outboard block by picking up a short Spectra loop and passing one end each through the forward and aft beckets on the underside of the boom and then connecting the shackle at the bitter end of the sheet through the ends of the loop, which will hold it clear between the fore and aft blocks.
svHyLyte is offline
post #6 of 8 Old 04-15-2012
You might just try moving the terminating eye of the mainsheet to the forward strap> If it leads clear there, than that is the way it was intended to be rigged.
davidpm likes this.
post #7 of 8 Old 04-15-2012 Thread Starter
davidpm's Avatar
This is an interesting idea. I would think that if the sheet was straight up and down it would have better leverage. But maybe the location was chosen because of loading issues on the boom.
davidpm is offline
post #8 of 8 Old 04-15-2012
mitiempo's Avatar
Quite often mid boom sheeting has blocks spaced out on the boom to spread the load out.
Brian
mitiempo is offline
what to use to stop chafing smallboatlover General Discussion (sailing related) 11 06-08-2011 03:15 PM
Mainsheet load on 31ft boat (need new block and cleat) MarkSF Gear & Maintenance 7 04-06-2011 12:45 AM
Jib sheet chafing coaming 4arch Gear & Maintenance 5 11-15-2009 11:44 AM
Mainsheet Block Stryker72 Gear & Maintenance 5 06-27-2008 12:34 PM
mainsheet block doctom Gear & Maintenance 8 02-26-2007 10:39 AM
