Paint my bottom? - SailNet Community
post #1 of 8 Old 04-14-2012 Thread Starter
Windkiller's Avatar
Paint my bottom?
Couldn't resist!
but seriously
As I search for a new tow vehicle I'm missing all this great sailing weather!
Waaaaaaaaaaaaaaah!
There's a local Marina (saltwater)where I can put my Danica 16 (actually 15) in for cheap cheap and cheap.
It's lived on a trailer and I'm guessing it hasn't had real bottom paint for quite a while.
It's bottom is brick red with what looks like old bottom paint (non shiny, porous powdery looking stuff) The gelcoat is beigy yellow underneath
Obviously it would've lost it's effectiveness long ago
I have no idea what paint was used and I'm not sure if I can find out
I'm going to put it in for a month so I can sail whilst I look for a tow vehicle This marina seems to grow mussles quite well and has a constant tidal current
Given that it's going to be in for a short time...annnd I don't know what was/is on there now
What would be a good choice and hopefully relatively expensive..and would it be entirely necessary for a short duration marina stay?
Thanks
Windkiller is offline
post #2 of 8 Old 04-14-2012
Re: Paint my bottom?
Which marina?.. for a month I'd give it a go as is.. if you notice rapid growth then drag it out for a scrub - easy enough for you.
Faster is online now
post #3 of 8 Old 04-15-2012 Thread Starter
Windkiller's Avatar
hmmm
I could borrow a car for a haul out scrub
Here's a completely dim question
Would osmosis be a threat in this short a time?
Or even worse..the Osmonds!!?
post #4 of 8 Old 04-15-2012
Sailor
Gladrags1's Avatar
Paint my bottom?
Osmosis wouldn't be a problem. I can't say about the Osmonds, depends upon your neighbor. Bottom paint does nothing to protect against osmosis anyway. You would need a barrier coat with a product like Interprotect 2000 for that. I would say launch her and prepare to scrape / scrub her bottom if things get bad. If water is warm enough, you can dive on your boat with a 6" paint scraper and make short work of the problem! When you have time, haul and scrape old bottom off. Then apply a hard ablative that is good for boats launched from trailers.
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #5 of 8 Old 04-15-2012
JimsCAL's Avatar
With a small boat like that, a quart of inexpensive bottom paint would be enough to give it a coat. Probably less work and hassle than having to clean it while its in the water. And if it takes longer than a month to find a tow vehicle, you're covered.
JimsCAL is offline
post #6 of 8 Old 04-15-2012
Senior Moment Member
SloopJonB's Avatar
Osmosis takes years to become a problem and even then it's really only a cosmetic issue (except in a few, very rare cases).
The Osmonds on the other hand.....
What Marina is it?
SloopJonB is offline
post #7 of 8 Old 04-18-2012 Thread Starter
Windkiller's Avatar
Out of curiousity what would you reccomend for a cheap bottom coat?
I don't know the paint that's on there
It's red and has a dull sheen, It doesn't seem to be in anyway flaking off
I was going to try and contact the previous owner but I'm not sure if it'll work
I've heard that the rustoleum bottom paint will paint over most paints and can be taken out for long periods but I don't know if you can buy it here
Any ideas for a cover all paint. my paint seems hard, has a dull sheen and doesn't look like it's flaking or has ever flaked.
So I need some sort of relatively inexpensive cover all bottom coat
I would of course roughup/clean mine before painting over.
I'd prefer not to have to sand the lot off
Any suggestions?
post #8 of 8 Old 04-18-2012
blt2ski's Avatar
If it is soft'ish, it is probably an ablative, if harder, then a hard paint, that should give you some what to go after.
I did put some WM ablative on about 15 months ago, so far, been better than the Micron that is covered over from a cleaning off stanpoint, and keeping slime etc off the bottom.
I did my 25' WL finkeel with about 3/4 of a gal, as mentioned, a qt of something should work on your boat. Give you some piece of mind for the next few months. You might find one that will allow it to dry for a bit of time vs some lose the anti foul property if out of the water for too long.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
Don Casey: Paint Waterline Stripe with Bottom Paint asdf38 Gear & Maintenance 23 03-05-2016 06:50 PM
Bottom Paint ... what to use McSwiggin Gear & Maintenance 8 04-08-2011 11:29 PM
Bottom paint prep, chipped paint josrulz Gear & Maintenance 16 02-14-2010 08:24 PM
how much bottom paint do i need? mountforever General Discussion (sailing related) 4 12-17-2009 07:52 PM
DIY bottom paint? bestfriend Gear & Maintenance 50 06-06-2007 12:06 PM
