Funny Electrical problem - SailNet Community
Blogs
Old 12-05-2003
Bruceo1 is on a distinguished road
I recently purchased a Manta 40 (catamaran). It has two Volvo Penta MD2030 engines. If one engine is started, the tachometer for that engine runs properly (either engine). When both engines are running, the port engine tachometer stops. The previous owner reported that the problem started when the alternaters were upgraded to 120 amp alternaters. Any thoughts or suggestions as to what is causing the problem and how to correct it would be greatly appreciated.
Thanks
Bruce
Old 12-05-2003
jbanta is on a distinguished road
Well over 90% of these kinds of problems are bad or improper common connection. I would look of the common side of the connection I an almost 100% sure that is where you will find the trouble.
Old 12-15-2003
Bruce_Olson is on a distinguished road
Thanks for the information. This should help me in getting the boat ready for the next sailing season.
Catalina 34 Starting Battery Problem Garytami Gear & Maintenance 6 03-07-2010 12:33 AM
Electrical Power Recharging Options for Extended Cruise Stormer Cruising & Liveaboard Forum 9 10-10-2006 03:07 PM
Electrical draw problem sailnaway Gear & Maintenance 1 12-13-2004 02:24 PM
1981 Honda 9.9, 4 stroke o/b, Idle problem randj65 Gear & Maintenance 4 06-19-2002 11:59 AM
Engine Oil Pressure Problem msamelso Gear & Maintenance 2 02-20-2001 07:25 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
