Non obvious ways to mess up boat systems - SailNet Community
 2Likes
post #1 of 15 Old 04-15-2012 Thread Starter
davidpm's Avatar
Non obvious ways to mess up boat systems or navigation errors.
A lot of boating is common sense.
For example if it too hard to turn figure out why.
Keep your head clear of the boom.
If it doesn't look right figure out why.
But not always.
There a several gotcha type things that are not always obvious to beginners.
You may enjoy adding to this list.
Things that you found out the hard way or things that you find you have to tell new people about on your boat.
davidpm is offline
post #2 of 15 Old 04-15-2012 Thread Starter
davidpm's Avatar
Re: Non obvious ways to mess up boat systems
Turn the battery switch to off, or even through off, while the engine is running. Often burns out the regulator.
Turn on the water heater element with no water in the water tank or an air bubble in the tank. Will burn out element.
Release the topping lift when no sail is up. Boom drops and hits the deck.
Cleat in the bow breast line when the boat is coming into a dock. Will cause the bow to crash into the dock.
Leave the head thru-hull open when sailing hard. The rush of water can cause the head bowl to overflow.
Chkm8 likes this.
davidpm is offline
post #3 of 15 Old 04-15-2012
chef2sail's Avatar
Ahhh there are many more to come....
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #4 of 15 Old 04-16-2012
Tartan 27' owner
CalebD's Avatar
Attaching a boat's batteries with the polarity reversed can also damage the regulator resulting in burnt diodes and non-functional alternator. BTDT.
Raising a halyard before checking to see if it is attached to a sail. BTDT.
Attach wrong corner of jib to halyard. BTDT.
Using dock horn cleats to hold a 50' boat to the dock in a 40 knot blow instead of using the pilings. BTDT and there was one less horn cleat on that dock when we left it.
Thinking that every member of your crew has the same feel for sailing your boat as you have.
I'm a bit surprised that the "Three Stooges" never did a sailing skit that I can remember. There are some great ways to torture your crew if you wanted to and many ways you can make them happy.
Everybody has one:
CalebD is offline
post #5 of 15 Old 04-17-2012 Thread Starter
davidpm's Avatar
On the same boat tying off boat to piling with clove hitch without the safety half hitches. The clove hitch will unravel. BTDT.
davidpm is offline
post #6 of 15 Old 04-17-2012 Thread Starter
davidpm's Avatar
Forgetting engine zincs. Saw that one on an impeccably owner maintained Morgan with a raw water cooled diesel.
davidpm is offline
post #7 of 15 Old 04-17-2012 Thread Starter
davidpm's Avatar
Tying a boat too tight at high tide on a fixed dock. As the tide recedes the boat starts to hang by the cleats.
davidpm is offline
post #8 of 15 Old 04-17-2012 Thread Starter
davidpm's Avatar
Following a string of buoys but missing one that forms a turn in channel.
Entering a harbor at the second buoy rather than the first. Works sometimes not always depending on draft of your boat and tide.
davidpm is offline
post #9 of 15 Old 04-17-2012
Tim R.'s Avatar
Check the tide tables before leaving the boat.
Photo courtesy of Maine Sail(not of Maine Sail's boat)
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #10 of 15 Old 04-17-2012
Jetexas's Avatar
When the new girlfriend decides to flush a tampon ...
davidpm likes this.
Jetexas is offline
Obvious electric boat idea davidpm Gear & Maintenance 23 06-15-2011 06:37 PM
An obvious case of injustice. !!! capn_dave General Discussion (sailing related) 3 08-16-2008 08:52 PM
Freya of Clyde: Always remember to check the obvious! @ Sail Blogs NewsReader News Feeds 0 04-14-2006 07:15 PM
