Replacing lifelines - SailNet Community
post #1 of 13 Old 04-15-2012 Thread Starter
davidpm's Avatar
Replacing lifelines
This is a Beneteau 32s5. I don't plan on replacing the lifelines this season but I was wondering how it would be done.
Replacing the threaded part and wire looks easy enough but I would think the part in the end of the rail should be replaced as well.
davidpm is offline
post #2 of 13 Old 04-15-2012
mitiempo's Avatar
Re: Replacing lifelines
Doesn't look like it is designed to be removable.
Brian
mitiempo is offline
post #3 of 13 Old 04-15-2012 Thread Starter
davidpm's Avatar
If so that seems like a very bad design.
davidpm is offline
post #4 of 13 Old 04-16-2012
Senior Moment Member
SloopJonB's Avatar
Indeed it does - no toggle to absorb side loads. Looks like it was done that way for production efficiency.
SloopJonB is offline
post #5 of 13 Old 04-16-2012
mitiempo's Avatar
It sort of absorbs side loads - the section in the rail acts a bit like a limited movement ball joint. Yes, bad design though.
I've seen that arrangement on other Beneteau boats.
Brian
mitiempo is offline
post #6 of 13 Old 04-16-2012
I sold my Beneteau last November but my experience with Beneteau USA was very helpful with the issues on my First. I strongly recommend that you contact them and ask for the help you need there. They have very good customer service. I have also recently replaced my lifelines on my current C&C sailboat and have opted for the uncovered lifeline of 1x19 wire rope and had a professional rigger cut to length and swage the end fittings. I took my old lines to him and just said to duplicate the length and new fittings. The uncovered 1x19 will last much longer since there is no plastic cover to hold the salt water on the wire for a greater length of time. I also opted to eliminate the lower lifeline (which cut my lifeline cost in half), and install mesh netting from the upper lifeline to the toe rail. I used zip ties to secure it. They will last a year or so under the sunlight but a bag of 1000 4" ties are less than ten buck and can be replaced as they fail or as an annual event of spring launch. It takes about one hour to do this chore and you have a better lifeline system than just two wires. Also, if you have pelican hook for your cockpit gate have them reused and polish them with PTEF polish, you'll save at least $30 per fitting and they should last you another 10 years. Good luck.
SISUMAN is offline
post #7 of 13 Old 04-16-2012
mitiempo's Avatar
True Beneteau is helpful bit I think it would take a magician to remove that fitting from the rail end.
The rest is easy.
Brian
mitiempo is offline
post #8 of 13 Old 04-17-2012 Thread Starter
davidpm's Avatar
I like the bare lifeline idea. For the Newport Bermuda race it it is the rule.
davidpm is offline
post #9 of 13 Old 04-17-2012 Thread Starter
davidpm's Avatar
The rest is easy.
Maybe the end can be cut off and some kind of a cap screwed on with the traditional loop at the end.
davidpm is offline
post #10 of 13 Old 04-18-2012
Sailor
Gladrags1's Avatar
Replacing lifelines
Maybe I'm missing something here. Could be as I have only looked at the picture on a small iPhone screen but why change that fitting that looks to be an integral part if the pulpit? It doesn't look in bad shape from what I can see. In replacing the lifelines the rigger would simply make up a set that had the same screw attachment that would screw into that fitting.
By the way, I strongly agree with replacing the lifelines with uncovered wire. You might want to go to the next size UP, not because of strength issues but visually you are used to seeing a certain size and the uncovered will look so different since it is thinner without that plastic cover. A thicker wire will also feel better on the hand. That's what we did when we replaced our lifelines.
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
replacing lifelines nodders Gear & Maintenance 11 02-26-2012 03:20 PM
Replacing Lifelines chef2sail Gear & Maintenance 2 12-29-2007 09:28 AM
Lifelines !! Freesail99 Gear & Maintenance 9 05-27-2007 07:59 PM
Lifelines - need help Suz Gear & Maintenance 11 07-07-2003 06:20 AM
Inspecting and Replacing Lifelines Sue & Larry Gear and Maintenance Articles 0 05-03-2002 09:00 PM
