Twisted mainsheet - Page 2 - SailNet Community
 9Likes
post #11 of 27 Old 04-16-2012
Old as Dirt!
svHyLyte's Avatar
Re: Twisted mainsheet
Originally Posted by davidpm View Post
This is a Beneteau 36s5
As you can see the block is twisted so the line is twisted about 2 full turns.
If I forcibly twist the block until the lines run fair the block wants to twist back up.
The problem is not seem to be that it is reaved improperly. It is just that the line seems to have taken a set.
I have seen this on may boats and just now gotten around to asking about it. It seems to increase the friction in the system and seems to be a bad thing.
Is there anything that can be done to fix this?
The block is twisted to the side because of the shackle connecting the bitter end of the sheet to the same becket the block is connected with. When the sheet loads up it will force the block sideways. Look at your other post concerning the bitter end of the sheet. There are several solutions to adjusting it's position which will also resolve your twist issue.
Tempest likes this.
svHyLyte is offline
post #12 of 27 Old 04-16-2012
blt2ski's Avatar
The other I am seeing, altho it may not be as big a deal as I see it, the knotted end is on the front of the block, line goes down to the front of the double, up back to a single then down to the back of the double up to the forward single to the mast. The double has two opposing lines with opposite pulls to either side. Both lines thru the double should be counterclockwise vs clock and counter to get the best pull on the blocks.
A single with becket at the top as mentioned would help this, or as I am seeing you have another thread, there was one or two other suggestions that would help in that one too.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #13 of 27 Old 04-17-2012 Thread Starter
davidpm's Avatar
Thank you all. I'm going to move the end point forward to at least eliminate the chafe and see what happens.
I don't think that will solve it though. Probably will need some kind of Becket.
I'll report back.
davidpm is offline
post #14 of 27 Old 04-17-2012
Tartan 27' owner
CalebD's Avatar
David,
We went through this with our main sheet too. Double blocks always caused twisting of our main sheet until we moved up to fiddle blocks for both the boom and traveler car, then no more twisting.
It costs some money to upgrade to fiddle blocks but it was worth it for us. Our traveler now has two double blocks and I hate it too as it tends to twist and bind but our main sheet passes easily between the fiddle blocks. At some point I'd like to replace the two double blocks with small fiddle blocks and not worry about it.
Probably the cheapest place to get hardware like this is from Garhaur: http://www.mauriprosailing.com/categ...Series-30.html
or where I may get fiddle blocks for my traveler set up: http://www.sailcare.com/fiddle-blocks.shtml
but those are only for up to 5/16" line.
Everybody has one:
CalebD is offline
post #15 of 27 Old 04-17-2012
tdw
Super Fuzzy Moderator
tdw's Avatar
I was bedevilled by the same problem until someone, I'm sure it was one of you lot, suggested a thin line from one to the other boom mounted blocks. Simply stops them from twisting. If you lay out the sheet every now and then to unwind the twist imparted by the winch all is well.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #16 of 27 Old 04-17-2012
Moderator
Jeff_H's Avatar
This does not appear to be a block problem or a problem with the block rotating. It is a problem with the way that the line is coiled and uncoiled. Even if the block is fixed so it can't swivel there will still be large frictional losses unless you learn to coil the line so you don't impart twist into the line.
Those who suggested taking the twist out are correct. On my boat I am religious about coiling the line to remove twists every time I coil the line. I so do by starting at the cleat (lock) and coiling using a figure 8 with every flake. The fast and easy way to do that is to hang one side of the flake on the handle part of a (locking) winch handle inserted in a winch and the other side of the flake hung over your fingers which works great if you hold one hand so that it forms a hook with the fingers up. This is pretty much standard proceedure to coil line on single handers and big race boats
davidpm likes this.
Jeff_H is offline
post #17 of 27 Old 04-17-2012
mikehoyt's Avatar
Agree with Jeff. Line has twist in it. Best solution is to replace line. Another temporary solution is to remove the twist from the line. Take line out of all blocks, tie one end to stern of boat and drag it behind for a few minutes while motoring. Then re run the line thru the blocks. Will help for a while.
I have the same problem and we trail it behind boat occasionally to remedy this. New main sheet is on the "List"
Mike
Mike
mikehoyt is offline
post #18 of 27 Old 04-17-2012
tdw
tdw's Avatar
Hey Jeff .... does this (although not using a winch handle) pretty much explain coiling ?
Video: How to Coil Rope for Sailing | eHow.co.uk
― Terry Pratchett.
tdw is offline
post #19 of 27 Old 04-17-2012
Moderator
Jeff_H's Avatar
Wombat: That is basically what I am talking about. The one thing that was not done right in the video is that you should work from the cleat outward so that the hackles can be released at the bitter end.
I also wanted to comment on lines holding a set. When you have double braid lines which has a twist in it while under load for a while the inner core can twist independent of the shell and create a situation where the line wants to twist when loaded. Reversing the line end for end should help, but I am not sure that towing the line is a permanent solution since the core may not release relative to the shell.
Jeff_H is offline
post #20 of 27 Old 04-17-2012 Thread Starter
davidpm's Avatar
So this sounds like one of the hi-tech braided lines without a core may have an added advantage.
davidpm is offline
A better way to run the mainsheet.... MedSailor General Discussion (sailing related) 5 02-25-2012 03:44 PM
mainsheet Packrat Gear & Maintenance 5 08-08-2008 08:00 AM
Javelin mast - twisted hinge plates sbeadgy O'Day 0 05-29-2006 06:32 PM
Mainsheet car Buck General Discussion (sailing related) 1 02-21-2006 01:44 AM
twisted keel wings BigZ General Discussion (sailing related) 2 04-25-2001 07:50 AM
