by passing Water Heater - SailNet Community
post #1 of 11 Old 04-16-2012 Thread Starter
One of None
deniseO30's Avatar
I need to do this since the HW is not needed unless I'm on the boat for a trip.
I've been wondering however; Can the coolant lines from the engine just be turned off with a valve in one of them? Seems to me they are "accessory" connections and should not interfere with engine coolant flow.
car heaters work that way, no?
jus wonnering
My last project!
deniseO30 is offline
post #2 of 11 Old 04-16-2012
JimsCAL's Avatar
Re: by passing Water Heater
Yes, assuming the heater is hooked up in parallel, not series, with the engine as is the usual way, it can be shut off. Not clear why you "need" to do this.
JimsCAL is offline
post #3 of 11 Old 04-16-2012 Thread Starter
One of None
deniseO30's Avatar
"rotten egg smelly water" from the heating and cooling I suppose. it's a new WH too.
My last project!
post #4 of 11 Old 04-16-2012
chef2sail's Avatar
I put ball valves on the coolant lines from the engine which go to the hot water heater as well as the return line back to the engine ( probably not necessary). I did this in case there was some kind of catesptrophic failure in the heater or the coolant line so the coolant could be shut off and not drain the engine
I do not shut them off as we use the shower all the time even though we dont often use hot water in the dead of summer I still run it so the stuff in the tank doesnt get stagnent or grow "stuff". The coolant always flow through the heater though .
dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #5 of 11 Old 04-16-2012 Thread Starter
One of None
deniseO30's Avatar
Valves on the coolant lines may be a good safety feature too Chef. The water in my HWH sits way too long and unused.
My last project!
post #6 of 11 Old 04-16-2012
BarryL's Avatar
Hi Denise,
You need to see how your WH is plumbed. On many boats the coolant flows from the engine block output (hot) to the WH, then to the HX, and then back to the engine input (cold side). If yours is plumbed like that you can't use a simple ball valve because it would stop all coolant flow. You could T the line TO the WH and T the line TO the HX and put a valve before the WH.
Personally I don't really see why you need to do any of this. I would just run some water through the heater. If it smells, run more until it doesn't smell anymore and be done with it.
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
post #7 of 11 Old 04-16-2012 Thread Starter
One of None
deniseO30's Avatar
What I've been doing Barry. I"ll look at it this week.
thanks everyone!
My last project!
post #8 of 11 Old 04-16-2012
JimMcGee's Avatar
Denise, you mentioned a rotten egg smell. Is there a high sulpher content in the marina water? If so filtering the water going into your tank might help.
Our marina was on well water in Barnegat and the odor was much more pronounced with the hot water. Just a thought...
You may also need to flush through some water treated with bleach to kill any critters growing in there. After a bad experience all water going into our tanks now goes through a charcoal RV filter .
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #9 of 11 Old 04-16-2012
chef2sail's Avatar
You need to see how your WH is plumbed. On many boats the coolant flows from the engine block output (hot) to the WH, then to the HX, and then back to the engine input (cold side). If yours is plumbed like that you can't use a simple ball valve because it would stop all coolant flow. You could T the line TO the WH and T the line TO the HX and put a valve before the WH.- Barry L
Our Yanmar 3GMF has two pulgs...coolant runs through the engine and also can run into the water heater. Putting the ball valves after the plug into the engine but before the hosing to the HWH alows you to close the coolant flow to the heater, but it still flows through the engine. Like I said its a safety mechanism in case of a hole in the hose to the water heater.
Dave
Parkville, Maryland
Our blog-
post #10 of 11 Old 04-16-2012
Your engine will warm up more quickly without the initial load of the 'cold' HW tank. However in previous boats we've had issues with re-establishing flow through the heater after it had been blocked. From a coolant flow point of view perhaps the safest thing is to pipe a bypass around the HW heater and keep the coolant flow(s) in the same path(s) all the time.
However, esp with a new heater the 'smelly water' should have nothing to do with the coolant coil in the heater - unless it smells like antifreeze. The domestic water piping/hose is a more likely culprit. Is it only the 'hot water' that smells?
Faster is offline
Water Heater galernikus Gear & Maintenance 18 07-15-2015 06:50 AM
LPG water heater WilliamWalker Gear & Maintenance 17 07-20-2011 11:34 PM
cs 30 water heater timmorgan CS Yachts 1 07-21-2009 06:01 AM
new water heater ralphmacey Announcements and Suggestions Box 6 05-26-2008 01:19 PM
Connecting raw water cooling to water heater Northeaster Gear & Maintenance 18 04-28-2007 06:11 PM
