Volvo Penta water pump shaft question. MD5A - SailNet Community
post #1 of 2 Old 04-16-2012 Thread Starter
GMC
After I take impeller cover off, I am able to pry my impeller out without loosening anything. The end of the shaft is slotted, so the small screw passes completely through the center of the impeller and then slides into the slot. Despite this set up, it does not show such a design in my manuals. Manuals show solid shaft with screw in impeller being used to tighten down on the shaft. Is mine a modification? Am I missing a part? The end of the shaft is forked or split to accept passage of the screw which has passes through the center of the impeller into the other side of the impeller. Does this make any sense? Thanks for any response.
Greg
GMC is offline
post #2 of 2 Old 04-16-2012
Courtney the Dancer
jrd22's Avatar
Re: Volvo Penta water pump shaft question. MD5A
Both of my Volvo impellers go on without any retaining screw/pin, not sure about the MD5 specifically though.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
Volvo-Penta Diesel MD5A/110S - Cold Start/Stop Control jbdoucet Diesel 4 08-06-2014 08:47 AM
Volvo Penta MD7A Injection Pump and Other Parts for sale SeaWolfe Introduce Yourself 4 07-04-2014 11:42 AM
question about old volvo penta MD7a bruno schmit Announcements and Suggestions Box 1 07-08-2011 02:21 PM
Volvo Penta MD7A Fuel Inj. Pump WRECKS Gear & Maintenance 2 09-01-2008 09:19 AM
MD3B Volvo-Penta sea water to fresh water conversion slosharron Gear & Maintenance 20 06-17-2003 09:08 PM
