bottom fairing - SailNet Community
post #1 of 11 Old 04-16-2012 Thread Starter
Windkiller's Avatar
bottom fairing
I'm looking to fair a spot on my boats bottom that's find of wavy
It;s a fiberglass hull with bottom paint over the gel coat
If I want to use a fiberglass filler compound (I know of a few, one that is supposed to be 'waterproof' ) Do I need to remove the gelcoat and get right down to the fiberglass or can I just sand the hard bottom paint off and fair over the gelcoat and then repaint?
I've tapped the hull in the problem area and it sounds like the glass is good.
I've also had a pro fiberglass person check it out and talked to the boat builder about it and they said it wasn't a structural worry
Windkiller is offline
post #2 of 11 Old 04-17-2012
mitiempo's Avatar
Re: bottom fairing
I would remove all paint down to gelcoat and fair with thickened epoxy.
Brian
mitiempo is offline
post #3 of 11 Old 04-18-2012 Thread Starter
Windkiller's Avatar
Re: bottom fairing
THanks
I should've bought some epoxy
i picked up some duraglass instead (it's a fiberglass short strand filler)
However I could likely take it back as it's unopened
Out of curiousity what would you reccomend for a bottom coat
I don't know the paint that's on there
It's red and has a dull sheen, It doesn't seem to be in anyway flaking off
I was going to try and contact the previous owner but I'm not sure if it'll work
my boat spends most of it's time on a trailer but I will be putting it in for a month, thus the desire to paint
I've heard that the rustoleum bottom paint will paint over most paints and can be taken out for long periods
Any suggestions
post #4 of 11 Old 04-18-2012
mitiempo's Avatar
Re: bottom fairing
It is unlikely that the duraglass will stay there long term - epoxy will.
If the paint is in good condition sand it with 80 grit and solvent wash before painting.
From the Rustoleum label:
Brian
mitiempo is offline
post #5 of 11 Old 04-18-2012 Thread Starter
Windkiller's Avatar
Re: bottom fairing
Do you know where I can find Rustoleum bottom paint up here
The local $@#$@$ home repo doesn't have it. I have yet to check crappy tire but Martin Marine (north van)doesn't carry it either
post #6 of 11 Old 04-18-2012
Re: bottom fairing
If I didn't know what the current paint was, I would bite the bullet and remove it. Shortcuts always cost me.
Jeanneau 54DS
Minnewaska is offline
post #7 of 11 Old 04-18-2012
mitiempo's Avatar
Re: bottom fairing
Rustoleum should have a dealer list on their site or you can email or call them.
Brian
mitiempo is offline
post #8 of 11 Old 04-18-2012
Superior Sailor
Squidd's Avatar
Re: bottom fairing
I got my Rustomeum from a Paint Dealer/paint shop (that services home painters and wall paper hangers etc..) They were able to order thru their dealer network...
Sounds like you have the same red, ruddy, lumpy, soft ablative I had on my boat (See "Sanding my Bottom")...
My understanding is the Rustoleum will NOT hold up over the soft ablative...which is what got me into sanding mine...
I would be OK over barrier coat, bare (primed) glass or another "hard" ablative ...but if you can scratch it with your fingernail...it's too soft...
FWIW
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is offline
post #9 of 11 Old 04-18-2012
Re: bottom fairing
If the boat is normally dry sailed and you are just putting her in for 4 weeks, I wouldn't add any more paint. Rather I'd scrub her myself a bit each week.
WDS123 is offline
post #10 of 11 Old 04-18-2012
Re: bottom fairing
In essence I agree with WDS for short term immersion.. just keep it scrubbed and avoid paint if possible.
But if you really want to paint WM locally has a pretty good deal on an ablative in-house antifouling at $100 for a gal.. pretty much half price - though I'm not sure how it would compare to Micron CSC performance-wise, for instance.... You could probably do your whole boat with a quart or litre.
Faster is offline
Fairing jblack General Discussion (sailing related) 7 10-15-2011 06:42 AM
keel fairing lofty22810 Gear & Maintenance 3 12-07-2008 05:21 PM
Keel Fairing BarryL Gear & Maintenance 34 03-21-2008 11:15 AM
bottom fairing and paint sailorbri Racing 4 09-22-2006 11:30 PM
Fairing katytoo Gear & Maintenance 1 03-26-2006 07:06 PM
