-   -   Transducer suspended in vegie oil. square to the bottom (http://www.sailnet.com/forums/gear-maintenance/8633-transducer-suspended-vegie-oil-square-bottom.html)
obiec 12-06-2003 05:14 PM
On a previous boat that I owned, the previous owner had adhered a round acrylic container to the bottom of the hull. it had a complete top on it and suspended in it was a transducer, it was in vegetable oil and seamed to get a pretty good lock on the bottom.
By using this cylinder you could point the transducer strait down and not at an angle with the hull. I am considering doing this with my present boat, Dose any one have any ideas on where or what I might find the materials. If it is acrylic will epoxy brake it down. What might work.
joub 12-07-2003 11:35 AM
The type of transducer you are speaking of is called an "in-hull" as opposed to a "thru-hull". The in-hull transducers can be purchased for around $70 at West Marine for one. They come with a suitable mount ready to epoxy/glue to the hull.
If you need a transducer that is probably the best way to go. If you already have a transducer, and just want to mount it, you can make a suitable mount/container out of PVC pipe.
One thing to be aware of is if your hull is cored in the area you wish to mount the transducer, you must cut out the core material so the transducer is "looking" through a solid laminate material.
Mineral oil is the usual liquid used to couple the transducer signals to the hull.
Jim
waltzingmatilda 12-12-2003 05:05 PM
Rather than using vegetable oil you should use mineral oil. Other than that, what you have outlined is pretty much the way it works. It does have to be aimed through an area that is solid fiberglass, though, and will not work on cored hull boats (boats that have balsa wood in the hull) since that would aim the transducer signal through air and that won''t work. Before you invest be sure that the hull is solid fiberglass.
ross99 12-18-2003 09:18 AM
I too have the WestMarine transducer and hull mount. The sleeve comes with a rotating angled piece so the transducer can be pointed straight down.
I stuck the sleeve to the hull with 3M 5200, filled it up with mineral oil, and have had no problems in three years.
pjfsail 12-19-2003 07:12 AM
What is the difference between an "IN HULL" transducer and an "OUTSIDE THE HULL" transducer? I recently bought a transducer and depth meter at a swap meet. It has a bracket on the transducer that is meant to be attached to the transom. Do you think it is possible this could be mounted inside the hull?
walt123 12-19-2003 08:44 AM
Yes, I mounted a "transom transducer" inside with no problems. You might try this trick, I had a relatively flat spot to mount the transducer. I used Silicon sealant, mounded it up making sure there wer not air pockets then gently pushed the transducer into the silicon and supported it in a vertical position for 24 hours until the silicon had set up. It worked perfectly. The hull was more than 3/8" thick where I mounted it and sloped about 30 degrees. This is a neater solution then constructing a container for oil. Good luck.
obiec 12-20-2003 03:55 PM
Thank you for all the replies, I have mounted several transducer in the past to the hull of my boats, But there are no flat spots on this boat. what I was realy asking was if Epoxy reson would brack down PVC or Poly carbon. For the person wonting to use the transom mount transducer go for it it will work. I have nerver like using silacone for the job but have always used a thikent Epoxy. On one boat I even built a dam about 3/8 high so I could ajust slightly for the hull shape. it worked will. I like the 5200 Idea and think I will use some 6" pvc pipe with 5200 to hold it. Will let you know how it turns out.
GordMay 12-20-2003 11:32 PM
5200 does not stand up well to oil, so you might use (3M) ''101'' instead.
Regards,
Gord
