Water in the Fridge - SailNet Community
 2Likes
  • 2 Post By olson34
post #1 of 6 Old 04-17-2012 Thread Starter
Water in the Fridge
I am pretty fed up with mopping out fridge. It has a drain but, of course, the fridge wasn't designed to slope down to the drain. Anybody sorted this problem? And please, don't tell me about the joys of sailing without one. Been there, done that.
kuching is offline
post #2 of 6 Old 04-17-2012
Mobnets's Avatar
Re: Water in the Fridge
Is it actually a refrigeration-equipped unit or a true icebox?
Mobnets
1973 Paceship Chance 32/28 "Westwind"
Mobnets is offline
post #3 of 6 Old 04-17-2012
Old as Dirt!
svHyLyte's Avatar
To protect food products at the bottom of the Ice Box from condensate, add at least one and preferably two layers of DryDecK that can be shaped to fit the box. This will create a space to collect the condensate and or melt water beneath the food products. Further, the next time you buy ice, preferably mid-sized chunks of Block Ice, have it vacuum packed or vacuum pack it yourself if you have something like a FoodSaver. This will prevent melt water from running off entirely and the bags of melt water can be refrozen. On trips, where you have to buy ice from time to time that cannot be vacuum packed, double bag the ice with over sized zip-lock freezer bags to contain the melt water, which can be used as it accumulates. We used the foregoing methods for many years before we had a refrigeration system and it worked well. (Also, unless you have a vapor trap-loop in your drain, put a plug in it to prevent your cold air from draining out.)
FWIW...
svHyLyte is offline
post #4 of 6 Old 04-17-2012
christyleigh's Avatar
My solution for many years has been to not create the water in the first place by making my own ice at home in 2 liter soda jugs. Dual purpose because the cooler full of food and beer gets packed with them so even after my 100 mile drive to the boat I transfer Cold food and beer, and Dry masses of ice into the boat fridge to help out with cooling. Also gives me Cold water to drink throughout the weekend.
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
christyleigh is offline
post #5 of 6 Old 04-17-2012
72 C&C Corvette
CorvetteGuy's Avatar
Enjoy a few boxes of wine. when your done clean out the bladder, fill with water and freeze, works great as they tend to lie quite flat in the ice box and don't leak, ready to be re-frozen..
CorvetteGuy is offline
post #6 of 6 Old 04-17-2012
Lightbulb Re: Water in the Fridge
We used to have moisture building up in our fridge (actually an "ice box" with a refrigeration unit added). This would coat the evaporator with ice after a week or three and then we would have to shut it down for defrosting and mopping up the melt water along with the accumulated water in the bottom.
I solved the problem by putting a sponge foam stick-on gasket on the lid where it sat on the flange.
With no more outside damp air entering (except when we actually open the lid) about 95% of the moisture was eliminated. Along with most of the ice buildup on the evap. plate.
So really seal up the lid (and any other air infiltration points like where the coolant tubing enters and exits).
Cheap fix and really effective.
Cheers,
LB
olson34 is offline
built a new fridge box janders Gear & Maintenance 2 02-07-2012 03:37 PM
What Fridge ? Tynesider Gear & Maintenance 9 06-09-2011 05:55 PM
Now fridge won't turn off! willynilly Gear & Maintenance 6 05-16-2011 05:20 AM
Water leakage under fridge XPAT Gear & Maintenance 3 01-03-2010 11:30 AM
Fridge Rodz47 Gear & Maintenance 8 09-22-2008 02:25 PM
