Marine Head plumbing - SailNet Community
 1Likes
  • 1 Post By arf145
post #1 of 10 Old 04-17-2012 Thread Starter
Unhappy Marine Head plumbing
I purchased my C&C 27 MK1 early 2011 and still trying to figure out the systems and years of improvised do-it-yourself fixes. In particular, I am having trouble wrapping my head around the plumbing for the head. I replaced the previous unit because I figured the seals were faulty due to the "colour and smell" of the clean water being pumped back into the head while flushing. I bought a new Jabsco unit and the installer used the same lines. Yesterday I was horrified to learn that the "clean water" was actually re-circulated waste from the holding tank. I had assumed that water was being pulled from the lake by means of a thru-hull. With a wife, 2 young children, and the friends of my 2 young children, I need a system that works!!
Thanks for your help,
Dan
Dan Burke is offline
post #2 of 10 Old 04-17-2012
72 C&C Corvette
CorvetteGuy's Avatar
Re: Marine Head plumbing
There should be 2 hoses on the head one to the holding tank and one to a through hull with a shut off valve in line somewhere. follow the hoses and see where they go. There should also be a vent line off the holding tank to the extirior of the boat. If there is no through hull for fresh water cap off the intake for the head and carry a 4 litre bottle of water in the head for flushing.
CorvetteGuy is offline
post #3 of 10 Old 04-17-2012 Thread Starter
Yeh, unfortunately both lines from the head terminate at the holding tank. I have a large compartment in the v-berth available- do you think a bladder with clean water would work if I re-routed the line to it?
post #4 of 10 Old 04-17-2012
72 C&C Corvette
I don't see why the bladder would not work as long as it is accessible to fill. Sounds like the other line should go to a deck fitting for pumping out.
post #5 of 10 Old 04-17-2012 Thread Starter
The larger of the 2 lines heads to the holding tank and than the same diameter line heads to the deck fitting. Do you have a thru-hull on your boat?
Thanks for your input.
post #6 of 10 Old 04-17-2012
Broad Reachin'
kwaltersmi's Avatar
The current issue of Good Old Boat has a nice illustrated write-up on "holding tank essentials" that diagrams several different systems.
Catalina 34
kwaltersmi is offline
post #7 of 10 Old 04-17-2012
72 C&C Corvette
Yes with a ball valve at the hull fitting, this line runs directly to the intake on the head
post #8 of 10 Old 04-17-2012
Irrationally Exuberant
We have a thru-hull for the flushing water--pretty common I think. However, we flush with shore water in bottles to reduce odor (we sail in bay water, not fresh), so we don't open the intake seacock. I like the idea of a bladder for flush water though.
chef2sail likes this.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #9 of 10 Old 04-17-2012
Send a message via Yahoo to dacap06
Recirculating, eh? One of the PO's really committed a bone headed change with that one! I'm wondering if the original intent was to flush using water from the fresh water tank to reduce odor? Changing from a through-hull to suck in salt water to tapping the fresh water tank would require a Y valve in the fresh water line. Depending on where it is located that could be easy or difficult ...
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
dacap06 is offline
post #10 of 10 Old 04-17-2012
Landlocked
moskalm's Avatar
NATURE'S HEAD...I know that doesn't help you're current situation, but really, consider it
moskalm is offline
How do I use this plumbing setup (Head)? YeahJohn Gear & Maintenance 8 01-15-2011 03:52 AM
Head plumbing according to regulations Petar Gear & Maintenance 6 12-28-2010 01:03 AM
Head Plumbing mwrohde Gear & Maintenance 7 06-13-2008 03:22 PM
vacuum break in head plumbing Artwerke Gear & Maintenance 3 01-18-2006 02:13 AM
Head Plumbing Stormer_2003 Gear & Maintenance 2 10-24-2004 07:51 PM
