Clean up the residue from butyl rubber? - SailNet Community
post #1 of 6 Old 04-17-2012 Thread Starter
A friend, who just rebedded all his deck hardware and stanchion bases with butyl rubber, complains bitterly about the residue on the deck, which collects dirt and pollen. He claims that he can't get it off. Are there any tricks or solvents to assist in the removal of the residue?
Hudsonian is online now
post #2 of 6 Old 04-17-2012
Tim R.'s Avatar
Re: Clean up the residue from butyl rubber?
First try a wad of butyl as the stuff usually sticks to itself better than to other surfaces. Acetone will do the trick if that does not work.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #3 of 6 Old 04-17-2012
72 C&C Corvette
CorvetteGuy's Avatar
The butyl tape goes under hardware how did he get it on his deck? Goo be Gone works wonders also.
CorvetteGuy is offline
post #4 of 6 Old 04-17-2012
But if not...
I just did the rebedding as well. Started the cleanup with a utility knife along the edge of the fitting, then peeled and removed the excess. Have to do it several times as the butyl slowly seeps out as the fittings settle. Suggest retightening the fittings a few times over a couple days to really get them snugged up. Then cut and trim the day after each retightening. Then a rag damped (not soaked) with mineral spirits or acetone for the final cleanup.
paperbird is offline
post #5 of 6 Old 04-17-2012
Tim R.'s Avatar
If you bed it properly, excess should squeeze out for months onto the deck.
Or he is just clumsy(like me) and dropped some on deck.
Tim R.
1997 Caliber 40LRC
Tim R. is offline
post #6 of 6 Old 04-17-2012
Maine Sail's Avatar
Bingo, except mineral spirits works better than Acetone. Meguiars Cleaner Wax, which has mineral spirits in it, also works well.
Butyl takes time to "displace" from under the fitting, especially if you "went heavy" on it. It can require multiple small tightening events until it stops. DO NOT try and compress it all at once as you can damage things. Let it oooze out at its own pace and it will stop when you are there..
______
-Maine Sail / CS-36T
Maine Sail is offline
remove 3M tape residue from topsides & interprotect gallilaw Gear & Maintenance 15 05-16-2011 02:02 PM
Where to buy Butyl Tape? sailak Gear & Maintenance 7 06-22-2009 10:27 AM
butyl tape pegasus1457 Gear & Maintenance 53 04-30-2009 05:58 PM
Why is there white residue on my deck? saurav16 Gear & Maintenance 5 05-25-2008 07:07 PM
How to Remove nasty glue residue from headliner? gratefulsailor19 Gear & Maintenance 4 02-07-2007 12:26 PM
