04-17-2012
Re: Diesel Fumes & Ventilation
Originally Posted by asdf38
So are you saying it's not necessarily to vent the engine compartment?
In previous years I sailed with the engine compartment open to the cabin. It's fairly recessed and the battery switch was placed within the compartment. So it was much easier to just leave the cover off (It's just a piece of wood and doesn't cut down on noise. Note, I never noticed fumes in the past). But as part of a re-wire I moved the battery switch out which gives me the option of actually using the cover.
Should I worry about venting? Of course it's far from air tight, there are openings to both cockpit lockers for wiring and engine controls which both have openings to the cabin for wiring etc.
Is your inboard engine gasoline or diesel? If your exhaust system is not leaking, the best reason to ventilate a diesel engine compartment is to reduce heat.
Venting a gasoline engine compartment should be obvious.
Tim R.
Living aboard in Portland, Maine
1997 Caliber 40LRC
