Fuel cap in cockpit: what kind of gas can? - SailNet Community
post #1 of 9 Old 04-17-2012 Thread Starter
scratchee's Avatar
Hey Folks,
I have a new Cal 2-27 with the fuel cap in the cockpit sole (gasoline, if it matters.) I'm having a hard time envisioning how to fill my tank without spilling fuel in the cockpit. Is there a gas can with a spigot-type valve on the bottom, like those Gatorade coolers? Or should I just use a standard gas can and only fill the can part way, so I can tip it down toward the tank before the fuel starts to flow? Any other ideas?
Thanks for any advice you can provide.
scratchee is offline
post #2 of 9 Old 04-17-2012
Chastened
Ajax_MD's Avatar
Re: Fuel cap in cockpit: what kind of gas can?
There are funnels with long spouts, or an ordinary funnel with a wide mouth will do.
I fuel my boat the same way, and with an ordinary, wide-bell funnel, I don't spill anything. You need to stop periodically and check the tank level to avoid spillage from overfilling though.
Or, have someone watch the guage level if you have a gauge.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is online now
post #3 of 9 Old 04-17-2012
Barquito
Barquito's Avatar
Mine is in the cockpit sole. Is a lot easier to fill at a fuel dock that has a normal gas nozzle. I put 15 gal. in the hard way once, with a funnel. I still spilled a lot of gas... not really what you want to do with gasoline on a boat. You could siphon gas from a can placed on a cockpit seat.
Valiant 32
Barquito is online now
post #4 of 9 Old 04-17-2012
Barquito
Barquito's Avatar
One other thing. I keep a wood stick handy to dip the fuel level. Let it air dry a little b/f tossing back into locker.
Valiant 32
post #5 of 9 Old 04-17-2012 Thread Starter
scratchee's Avatar
Thanks guys.
Of course, two minutes after posting I found http://www.amazon.com/No-Spill-1450-5-Gallon-Poly-Compliant/dp/B000W9JN4S/ref=sr_1_2?ie=UTF8&qid=1334682352&sr=8-2 that has a valve like I described. So it looks like I have some options.
post #6 of 9 Old 04-17-2012
Not sure about your area, but here in Ct the only fuel containers that you can buy are the ones with the safety spouts on them. They are suppose to be designed to prevent spilling. You can tip them into the fill opening and then open the spout/vent. They are a little slow to fill and also a pain in the a**, but you won't spill. We also cut a piece of spill diaper with a hole in it to put down around the fill.
Peter
justified is offline
post #7 of 9 Old 04-17-2012 Thread Starter
scratchee's Avatar
Thanks Barquito. I do have a wood dipstick. The guy I bought the boat from said he got it from the owner before him. That was 28 years ago!
post #8 of 9 Old 04-17-2012
S/V Lilo, Islander 32
I to have my gas fill in the cockpit. I fill exclusively from cans as the pumps are to fast and the fuel backs up the fill pipe and spills all over. The previous owner of 27 years did the same thing, neither of use can figure out why this happens. The fill pipe seems big enough and is straight down to the tank with no bends or obstructions, only 6 - 8 inches, and the vent seems to be clear. Oh well....
I actually prefer the cans with out the valves, and I just put my thumb over the end until it's over the fuel fill (and keep one of the absorbent pads handy). I may spill a few drops this way, but not much at all and it evaporates before I'm done fueling. The valves are handy for not spilling, but then you have to hold them open (at least the ones I've found) I can't find any cans without the valves anymore, so I'll often switch the one none valve top I have left between cans.
Either way, valve or no I would stress about it too much. The nice part about having the fill there is it's easy to fill on the water if needed without hanging over the side (Still shut down the engine, close the hatch, run the blower, etc) and if you spill a little, it's not going in the water and is easy to clean up. Just be sure you can take the time to let everything air out well, and run the blower for a while after filling as always.
Enjoy the new boat!
S/V Lilo
1964 Islander 32
Saint Helens, OR
IslanderGuy is offline
post #9 of 9 Old 04-17-2012
Some fuel tanks have an extending pipe inside to close to the bottom.I guess there were reasons why this was popular. {foaming diesel?} But it prevents filling the tank faster than the vent will allow air out .I T'eed into the deck fitting{ up close} a larger vent hose which comes into play when open to fill. Actually, I ganged both deck fitting together and open both while filling .Good breathing allows me to take on 800 liters quickly without spitting.
Capt Len is online now
Center Cockpit Versus Aft Cockpit BlueWaterBlair General Discussion (sailing related) 58 03-19-2012 12:35 PM
City marina to build self-service fuel station after three years without fuel - Corpu NewsReader News Feeds 0 07-16-2011 11:40 PM
Aft Cockpit vs Center Cockpit AjariBonten Boat Review and Purchase Forum 26 11-05-2007 01:53 PM
Center Cockpit vs. Aft Cockpit. badadim Boat Review and Purchase Forum 29 07-19-2007 07:44 PM
Center cockpit or aft cockpit? capsbond Boat Review and Purchase Forum 11 08-09-2006 12:28 PM
